Pulling nails & hardware out of burn pile ash
   / Pulling nails & hardware out of burn pile ash #21
lol... hell will freeze over, before I start pulling every nail and staple out of every pallet or other item I burn! :ROFLMAO:
Original post didn't mention pallets, but agree, even if you wanted to, it's almost impossible to get the nails out of pallets (n)
   / Pulling nails & hardware out of burn pile ash #22
That's what I have, and it does not work well for me in rough terrain or soft terrain.
I like @RjCorazza's 750lb magnet tool. That sounds effective.
All the best, Peter
Interesting! I burnt 3 couches in my back yard which is what made me buy this magnet. My yard is not smooth in this section as I drive the tractor around there constantly, but not heavily rutted either. I had thousands of staples and screws left over after the burn and this worked extremely well for me, and quick too!
   / Pulling nails & hardware out of burn pile ash #23
I've always wanted to collect about five old automobile air conditioner pumps to salvage the clutch coils to make an electromagnet. They pull about 4 amps, so a 25 amp circuit should power a gang of them mounted to a board and skinned with thin material so stuff won't go up into the coils.
   / Pulling nails & hardware out of burn pile ash #24
I took a magnet from an old speaker and zip tied it to a metal leaf rake. It works well for finding the nails but you spend a lot of time pulling the nails off of the rake.
   / Pulling nails & hardware out of burn pile ash #25
Good idea! Couldn't you just take the magnet off to release them?
   / Pulling nails & hardware out of burn pile ash #26
   / Pulling nails & hardware out of burn pile ash #27
1000 pounds should be enough & in a thick plastic bag makes it easier removing metal.
   / Pulling nails & hardware out of burn pile ash #28
I just purchased a rolling magnet at Harbor Freight two weeks ago for this very reason and it works extremely well. LINK
Have that same magnet that I use to sweep around old buildings at farm before I bush hog. Amazed sometimes at number of nails I get sometimes.
   / Pulling nails & hardware out of burn pile ash #29
I just got done cutting up a big flail mower pallet with a cordless chainsaw. Big pieces go to the woods. Burning them isn't worth the trouble, since they will vanish in two years. Medium-size pieces to the big landfill that takes construction debris.
The little local dump won't accept construction debris, so the little pieces with nails will either to go the big dump today, or I'll sneak them into the household garbage tomorrow and take them to the little dump.
I don't know the model number of the Harbor Freight magnetic rake, but it's the big one. I don't know if it's as good as the pro rakes, but Project Farm likes it.
1000 pounds should be enough & in a thick plastic bag makes it easier removing metal.View attachment 4332166
Done. Fuddy has the winning solution, for me!
I suspect most plastic bags will just tear, trying to pull off that magnet full of nails, put perhaps an old grass seed bag or burlap bag... or even a sheet of plexiglass?
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
66'' root grapple (A53421)
66'' root grapple...
2007 GMC C8500 Altec DL45TR Insulated Material Handling Digger Derrick Truck (A55852)
2007 GMC C8500...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2004 Jeep Liberty Limited SUV (A55853)
2004 Jeep Liberty...
