led bulbs in bx2680 for signals / hazards
   / led bulbs in bx2680 for signals / hazards #1
tjstractors
Great White North
Kubota BX2680 w cab.
For anyone that put led bulbs in the amber signal /hazard lights on a current model bx80, did they hyper flash needing a resistor or different flasher relay?
   / led bulbs in bx2680 for signals / hazards #2
Not in a BX, but my L4060 led conversion did not require anything additional. I have no doubt requiring a resistor is a thing in some cases, but across (3) tractors, and (4) road vehicles I've never needed anything additional.
   / led bulbs in bx2680 for signals / hazards #3
I put LEDs in for headlight bulb replacements in our BX2200. They work fine as-is. No other changes. Of course there may be many kinds/varieties of LED bulbs but if they are specified to be 12v and fit the socket you won't need anything else. Plug in and go.
I've done headlights and tail lights but never tried signals. I'll give it a go. I know in some cases it isn't enough load so the flasher hyper flashes instead of the normal speed. One way to find out.
   / led bulbs in bx2680 for signals / hazards #5
I suspect the flashers will work ok. Not counting the led headlight conversion I shaved off 11 amps of load using led bulbs in my running lights and flashers. With incandescent lighting, added front and rear led cab lights, and cab window defrosters I was way too close to the alternator's capacity.
I am adding a light bar front and rear but that isn't a lot of total draw. Probably 8 amps. I can certainly offset a lot of that by going to all led on the other lights. I'll just buy them and see what happens. It isn't a very big investment.
   / led bulbs in bx2680 for signals / hazards #7
I put LEDs in the blinkers on my BX2230 and they work fine. I believe the flasher unit is electronic and doesn't care what type bulb it is flashing. The schematic shows a flasher unit, no separate flasher.
   / led bulbs in bx2680 for signals / hazards #8
I have had problems with LED bulb bases getting hot and melting plastic light housings. Any suggestions?
   / led bulbs in bx2680 for signals / hazards #9
Do you have a canopy? This is what I did on my bx2680 for lighting.
Front:
Rear/side:
(there is a pair on each side)
Fantastic light coverage! Total load is 8amps measured.
Sent from my SM-S921U using TractorByNet mobile app
   / led bulbs in bx2680 for signals / hazards #10
Better bulbs? Higher quality bulbs are typically more efficient so less heat output, there are also some that have external heat sinks to get the heat out of the housing.
  • Good Post
Reactions: bgr
2018 Chevrolet Tahoe (A55973)
2018 Chevrolet...
2019 Cummins L9N 8.9L 6-cylinder Turbo Diesel Engine (A55851)
2019 Cummins L9N...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2012 Ford F-150 Ext Cab 4x4 Pick-Up Truck (A55852)
2012 Ford F-150...
