How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench?
   / How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #51
Perhaps you don’t understand reality due to lack of experience.
   / How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #52
I understand that I’m working with budget constraints every day and I can’t afford to make every single thing 2-3 times more expensive against an extremely small chance of a slightly harder repair. We’re laying 300 ft of conduit here a fairly easy diy job it’s not building a nuclear reactor. And you keep diverting without answering my original question. Have you ever successfully dug up and repaired a residential service line without just ripping up the entire thing and replacing it anyway?
   / How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #54
Dig the ditch…..install electrical……once it’s passed out the 2” in right on top of sand covering the other conduit
I mean once it’s passed who’ll know what’s under it
Need to have a minimum of 12" between power lines and cat 5e/6e data cables with all crosses at right angles or there WILL be data speed lost or NO data if the run is long enough. Optical fiber lines need much less separation, like >2 inches. If I was doing is I'd spend the extra money and use direct bury cable. The reason is that direct bury is water proof and I don't think that I would warranty that job any other way because, between both entry points and all the joints, I don't think I could keep water out of the conduit.
By the way 300 feet is the max distance for CAT 5e/6e before data speed drops to a unusable speed.
   / How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #55
Ok, so, by the time the wire is an issue in conduit, the conduit is nearly always unusable. That UG power wire should last 40 years. Find me some conduit from 1985 that you can A, pull the old wire out of, and B, blow a string and pull new wire?
So, I dont want to say dont do it per utilities spec, do it their way. The telecom, whatever. In the end, if it fails, someone will just rerun it in 40 years
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
66in Bucket Skid Steer Attachment (A55851)
66in Bucket Skid...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A55851)
Generac Yanmar...
2025 Electric Cart (A55853)
2025 Electric Cart...
