You Know You Are Old When
   / You Know You Are Old When #6,351
Yep, we had one in our shop back in the 70s. We salvaged it out of a gas station we demolished a few years before. The air valve shown pressurized a tank of oil that pressurized the big hydraulic cylinder on the lift.
There's usually an air-driven hydrualic pump, in these setups, as 100 PSI in any hydraulic cylinder of reasonable size is not going to lift a car.
Air driven hydraulic pumps work by having a piston with an "air side" and a "hydraulic side", where the bore in the air side is many times larger than the hydraulic side. Think of it as two pistons with their rods tied together, a big one for air and small one for hydraulic oil, with the ratio of their cross-secions (A = pi*r^2) being the pressure multiplier. There are some valves on the associated inlets and outlets that cause the whole rig to cycle like any reciprocating piston engine, delivering flow at the desired pressure on each stroke.
   / You Know You Are Old When #6,352
The one we had didn't have a hydraulic pump, only an oil reservoir pressurized by air. I helped remove the lift from the gas station site, and remember that the main lift cylinder was large, at least 18" in diameter. I was also there when we dug the hole, put forms around it, then poured concrete around it.
If you do the math, an 18" piston at 100 PSI gives you over 25,000 LBS of force, far more than needed to lift any car or pickup at the time. The shaft that came out of the floor was about 12" in diameter, and had an H shaped lift frame made of 4" I-beams. We fabricated slides that rode on the I-beams that were placed under axles or lift points to raise the vehicle. It had no safety latch to keep the lift from leaking down, so we made a couple of different lengths of 4" diameter pipe to place under the lift frame next to the lift shaft to hold it up. The bad part of using it was that we set the lift frame into the floor, so when it was raised, you had to contend with the trenches in the floor where it sat when retracted. It was really handy when removing the belly pans under dozers and earthmovers to clean them out or perform maintenance.
You did have to keep the load on it pretty much centered or it tended bind up due to the side loading.
   / You Know You Are Old When #6,353
This little service station is still on the corner of LaPorte and Walnut in South Bend. As I recall, it was owned by a man named Steve Starzinski. (think that was the name on it). It had a gas pump out front and to the right of the building as you faced it they had a single post hydraulic lift outside. I still remember seeing a guy standing under it working on cars, winter, summer, didn't matter. You can still make out the concrete tracks where it set into (if you use your imagination 🤣 )
   / You Know You Are Old When #6,354
   / You Know You Are Old When #6,357
When I was growing up you used to see all sorts of little gas stations like that, some kind of in the middle of nowhere. Don't remember seeing any that had an outdoor lift. Indiana winters probably aren't as cold as those here in N.H., but still wouldn't want to be outside working on a vehicle if I didn't have to.
   / You Know You Are Old When #6,358
My Dad had a International tandem logging truck with a Prentis cable loader (haul 5 cords). From the age of 13-17 it was my job to change the oil and grease it in the snow bank, no garage.
We could have highs of -10 to -15 during the day. If something broke he would fix it.
   / You Know You Are Old When #6,359
It had to be done in winter? Not spring, summer, or fall? :unsure:
   / You Know You Are Old When #6,360
None of my stuff breaks when it's convenient either. I try to service all my stuff before winter. I learned a trick to fixing my car when it was below freezing. I only used tools that I could soak in a bowl of hot water and I could work twice as long. It had to get done.
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
HIGH END ELECTRIC GOLF CART (A55745)
HIGH END ELECTRIC...
2013 John Deere 824K Wheel Loader (A57024)
2013 John Deere...
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
MINI SKID SDLL50 (A55745)
MINI SKID SDLL50...
