Hy
Jonsdeere
Does anyone use something like Armorall on their hoses?
Does Armor All help protect rubber from UV deterioration? That would be the only benefit I could see unless trying to polish for show tractor.
Don't know about ArmorAll, but ProtectAll does provide UV protection to rubber and plastics. I use it on practically all non cloth surfaces.
I think a better option would be to cover the hoses with those protective sleeves for hydraulic hoses.
Time consuming and a bit messy to install, sure, but would provide another layer of protection against UV and to the operator from a shower of hydraulic fluid in case of an hose burst.
Not with a product like the Dura-Wrap we sell, it has a velcro closure.
  • 1-1/4″ is perfect for two 1/4″ or 3/8″ hoses, or 5/16″ – 3/8″ chain
  • 2″ is perfect for four-six 1/4″ hoses, or four 3/8″ hoses
  • 2-1/2″ is perfect for two 3/4″ hoses
Dura-Wrap© is the perfect solution for organizing and controlling cables and hoses that are subject to constant exposure. This sleeving is made from one of the strongest materials known, ballistic nylon. The tightly woven nylon is paired with an industrial hook and loop closure to provide a durable and flexible sleeving that’s super easy to install.
Dura-Wrap© is ideal for keeping wires or hoses together or covering chains and hoses to protect the surfaces they run across. The sleeve provides the best abrasion resistance and water repellence when compared to other nylon sleevings.
The flexibility featured by Dura-Wrap© makes it easy to install over single or multiple hoses without having to disconnect them. The high strength and durability also help to protect operators or other personnel safe from high-pressure fluids that may be traveling in the hoses.
  • Tightly Woven Ballistic Nylon Construction
  • Heavy Duty, Oversize Hook and Loop Closure
  • Repels Liquids
  • Resists and Prevents Damage from UV, Abrasion, Gasoline/Diesel Fuel, Mild Chemicals, Salt Water
  • Deflects High Pressure Ruptures
  • Quantity (150′ or more) Discounts Available
  • Other Popular Sizes Coming Soon
  • Repels Liquids
I can't open your website but I think I have an idea of what it is.
This is what I used on all of my hoses, and the 1.25" size for a couple of larger hoses. Worked great.
Pics as I installed them on the FEL and backhoe. As previously mentioned, they protect the hoses from UV and chafing.
Chris
When I replaced the hoses on the FEL on my M4900 I just used split loom tubing with a black cable tie at each end. Wanted to keep the sun off them as tractor sits outside all the time.
x2 on keep it out of the sun.
I know the fuel hose that I have in a sleeve protector has remained flexible were as the other tank I have, the hose is stiff!
At my age the hoses will out last me.
I started covering all the hoses I replace with a nylon sleeve, mostly for UV protection, but also for abrasion.
Sent from my SM-S921U using TractorByNet mobile app
Nice job. What are you using on the sleeve ends to fasten them?
I used these
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
2014 International WorkStar 7500 T/A Dump Truck (A61573)
2014 International...
2010 Scag STT52V-27CH 52in Zero Turn Mower (A61572)
2010 Scag...
