ponytug
Super Member
Any chance that you could put your tank outside? Your well will be adding 54F water, and you keep drawing water from it, so with a little insulation it might be ok. I don't know how close you are to Lake Erie and the storms.46F, moist, and overcast @ 14:45, only calling for a high of 48F for the day ... will not be doing any outside work today ...
Low this morning was 43.5F, nearby LWS reports yesterday's rainfall was 0.19".
Did not get Menards order completed.
Instead I mostly worked on researching/pricing components for a bulk water storage system.
Was pleasantly surprised to find that it appears to a very cost effective solution, as David suggested. At least compared to having a new well drilled.
Main components that would be needed that I don't already have are:
1. Storage tank (or tanks)
2. Float switch to turn off the submersible pump in the well when the storage tank or tanks are full.
3. Booster pump to provide pressure for the house.
4. Sanitation (UV light and/or other solutions)
Total cost could be as low as $1800 to $2000 not including sales tax. That assumes my labor (free) to cobble it together.
The maximum width of the door going into the utility room is 36" ... if the door and trim is removed.
It looks like that would limit the tank size to 300 gallon or less.
Chem-Tainer offers a 300 gallon vertical tank that has a 34.5" diameter and is 84 3/4" tall and has a 3 year warranty.
Complies with FDA standards 21 CFR 177.1520 (1) 3.1 and 3.2 and uses a UV Stablized Resin to prolong tank life. Excellent impact resistance. Features a 16" Vented Manway, 1-1/2" inlet, and 2" outlet. Weighs 87 lbs.
National Tank Outlet has it available for $540 from their various warehouses in the US:
300 Gallon Chem-Tainer Black Plastic Vertical Water Storage Tank
Closest to me is in PA, over by Harrisburg. Freight would be $275 to $335 depending on whether it's going to a residential or commercial location. Could save the freight if I go and pick it up.
Initial quick check on a Square D float switch looks like in the ballpark of $140.
1/2 HP Little Giant shallow well pump from Menards is $240 (before rebate)
UV sterilizer is $250 to $500 depending on model from Menards (before rebate)
Total outlay looks to be $1170 (on the low side) to $1960 (on the high side), depending on whether 1 or 2 tanks and the particular UV sterilizer selected. That assumes I make the trip to pick up the tank (or tanks) at the warehouse in PA.
Should pretty much have all the pipe (1" PVC + 3/4" copper), fittings and valves already in inventory that would be needed to plumb it.
Open to any thoughts and other input ... want to make sure I don't miss anything.
Not sure what all will be on the agenda for the rest of the day but I'm sure something will turn up ...
Hope everyone is having a decent day ...![]()
FWIW: This is the style float switch I have been using. Going on 11 years or so.
Loading…
www.amazon.com
The last one I bought was made in Argentina of all places.
All the best,
Peter
