Are replacement tractor parts made out of solid gold?
   / Are replacement tractor parts made out of solid gold? #21
I checked TractorHouse, they have more than several complete brake actuators, used and new aftermarket. Used ones don't look too bad, one for $135, another for $161 and change: 368293R91 Parts For Sale | TractorHouse.com
Thanks for the link. I seem to get lost on TractorHouse for some reason.
If the complete assembly is available new for $225, surely some of the subcomponents are available somewhere for cheaper. I may hunt some more, or at least make some noise at some of the vendors. For now I went ahead and welded a washer to the end of the stud and put it back together. Not permanent, but good enough that I can move the tractor and use it for the next few days.
Of course, sometimes it is just fun to play a bit too. ;)
The braking surfaces of my parts are moderately pitted. Since I'm not racing Formula 1 with the tractor, perhaps some pits will be OK. If I get a little better organized, I could try to fill the pits (weld), and machine the surfaces.
These are the parts I snagged from E-Bay. Dirty, and not great photos, but the price seemed good, and they didn't appear to have the rust problems that I have. It will give me some stuff to play with. I'm pretty sure one of the inner seals is leaking, so I need to track that down before I make too big of a mess. Perhaps I can completely rebuild it off tractor then reassemble.
Ebay Brake parts 1
Ebay Brake parts 2
   / Are replacement tractor parts made out of solid gold? #23
That's a pretty good price. Be aware that to need to drop the bull gear to pull that bull pinion assembly out if you're not aware of that. Note the notch in the bull pinion bearing cage. Also only remove one side at a time because the internal gears can drop.
For any parts you may need, open this link to the Case/IH online parts book for the 606. International Gas Tractor | Case IH | MyCNH US Store Scroll down to see brakes and select. Hopefully the bearing is OK, they are outrageous through Case/IH. You can copy and paste the part number to NAPA and they usually cross to the national part number. One you get that part number copy and paste that to Google, or Ebay. I bought sets of bearings on ebay from a seller called Patriot Bearing Supply: Security Measure | eBay All NOS U.S.A Timken bearings for 1/4 to 1/3 the price at Case IH. If it's not in his listing send him a message, he has thousands of bearings not listed. Normally has free shipping too, great guy to deal with.
If you replace the seal without removing the back plate, here's a tip when installing new seal without inverting the seal lip on the splined shaft.
Wrap the shaft with electrical tape starting on the smooth part just outside where the seal rides and wrap outward the full length of the shaft and leave a 1" tail beyond the shaft. Oil the tape, then slide the seal over it, turning it slightly as you push it on, sorta like following threads on a bolt the same direction the tape is wrapped. Being the tape is wrapped from the inside out there are no sharp edges for the seal lip to catch on, it rather jumps over the edges of the tape. When the seal is in place, grab the tail of the tape at the end of the shaft and spiral it off. I've used this method numerous times and have never rolled a lip on a seal. I learned this method 20 years ago from an old Massey-Ferguson mechanic either here on this forum, or another I frequent often. So simple, not sure why I didn't think of it at the time.
Thank You
   / Are replacement tractor parts made out of solid gold? #25
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2019 XL 110 HDG RGN TRAILER (A55745)
2019 XL 110 HDG...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2016 SKYJACK SJ40T MANLIFT (A52706)
2016 SKYJACK SJ40T...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2015 FORD E350 16FT BOX TRUCK (A56129)
2015 FORD E350...
