Working rail roads and their tracks.
   / Working rail roads and their tracks.
Brady did a nice video on the derailment in Ohio when those toxic cars burned in 2023. I also think those hot-box detectors (hot bearings) should be set at a lower, safer setting.
   / Working rail roads and their tracks. #4,202
From what I have read, a steam locomotive only went around 60K miles if working in mountains, a few more miles in the flats, 80K before rebuild. A heavy repair would take 6 to 7 weeks.
And yet, they'd get well over a million miles out of them over their lifetime. Amazing machines.
   / Working rail roads and their tracks. #4,203
If I remember correctly, the Mesabe Iron Range Yellowstone locomotive on display in Duluth, MN had well over a million miles on it when it was retired.
   / Working rail roads and their tracks. #4,204
Just saw it two weeks ago! (y)
   / Working rail roads and their tracks. #4,207
The modern Timken locomotive journal bearing, aka GG, rolling element, will do a million miles. It is an opposed tapered roller bearing.
The problem is the wheels will not do a million miles. And when the wheels are changed, the journal bearings are removed and you cannot remount the journal bearings unless they has been requalified.
Depending upon the track conditions and truck design, the wheels can last anywhere from 250K to over 500K miles?. These are approximates. I cant remember the advertised numbers.
When I first started as an apprentice in the late 60's we were still making what is called a friction axle. It had friction, aka plain bearings for the motor suspension and friction journal bearings.
The motor suspension was a Babbitt bearing but the journal bearings were a bearing bronze, like SAE 660. Both used a felt wick to apply the oil to the load surface. These journal bearing were the ones BravoXray was referring to that were stolen.
Boat and rail pic.
CN's day hill job R921 spots ore cars for dumping at Dock No. 6 as the Hon. James L. Oberstar loads UTAC pellets for Indiana Harbor, its first trip after being at Fraser nearly four months undergoing repairs. The new face of the Missabe, GE AC44C6Ms 3321 and 3313, provide the power. Duluth, MN - October 6, 2025
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2012 Big Tex 25ft. 9 Ton T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 Big Tex 25ft...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
set of 4 wheels and tires 205/75R15 (A56435)
set of 4 wheels...
