Help - Can't figure out how to fix hydraulic leak on Kioti CK2620
   / Help - Can't figure out how to fix hydraulic leak on Kioti CK2620 #1
kiotick2620_2024
Kioti CK2620
Hi All - I am new to the forum, and also fairly new to tractors in general.
I have a Kioti CK2620 that is about a year old (first tractor).
I have a leak from a hydraulic line connection where the hoses come up and connects under / to the right of the seat. Picture attached.
There are four lines that connect into this area and it is so tight I cant figure out how in the world to get a wrench on it and tighten it.
Anyone encountered this issue before? Advice?
Trying to avoid having to trailer to the dealer to fix a simple loose connection leak, but I am baffled by how inaccessible this connection seems to be.
   / Help - Can't figure out how to fix hydraulic leak on Kioti CK2620 #2
   / Help - Can't figure out how to fix hydraulic leak on Kioti CK2620 #3
What @Racer4 said, they are called tubing wrenches also. Picture a box end wrench with a slot cut in it large enough to get over the tube and then slide up to the fitting and tighten.
Thank you both so much.
I will order a set and see how it goes.
   / Help - Can't figure out how to fix hydraulic leak on Kioti CK2620 #5
In some cases you may have to remove a line or two to gain access he problem. Just be 110% certain to identify which hose goes where so don’t create it doesn’t work problem…
   / Help - Can't figure out how to fix hydraulic leak on Kioti CK2620 #6
When I bought my used Kubota, it leaked from the valve manifold. The guy who sold it to me said it was no big deal. He said he just topped it off once in a while. He said it needed some kind of repair or other. I think he said it needed new couplers.
The valve was installed so everything was very hard to access, and because I assumed this guy wasn't stupid, I figured I would just top it off until I felt like having a dealer fix it.
One day I removed enough stuff to get at the couplers, and I tightened things up. Leak gone.
Made me wonder if the previous owner had any idea how things worked.
   / Help - Can't figure out how to fix hydraulic leak on Kioti CK2620 #7
A couple months back I had a leak on my CK2610 from the very same place…
Unfortunately I don’t recall exactly all of the bits I needed to remove, however, I began with the plastic cover just as you did. The vertical metal panel at the rear of the floorboard (which houses the fwd/diff lock levers) also came off… it bolts on either side to the rear fenders…
I was able to access the entire valve at that point… all with standard wrenches…
I spent more time fretting on how I was gonna do this than I actually spent on doing it… like you said, I could see the leak, but I couldn’t reach it just from the top…
   / Help - Can't figure out how to fix hydraulic leak on Kioti CK2620 #8
While you're in there, see if there's supposed to be a bolt in that bracket. It's the hole to the right of the plastic bushing. Might be a good idea to check the tightness of all the bolts in there. :oops:
Note: "Tubing" wrenches (AKA "Flare Nut" wrenches) are not the same as Crowfoot wrenches. ;)
   / Help - Can't figure out how to fix hydraulic leak on Kioti CK2620 #9
P.S. To my previous post… yes… use a flare wrench on the hose connections! (I purchased a rather inexpensive set from HF last year for another project… good investment…)
Also, I “removed” the rubber boot from the FEL joystick… just remove the bolts holding it and slide it up the shaft… lets you see anything that might also need attention…
   / Help - Can't figure out how to fix hydraulic leak on Kioti CK2620 #10
Sidebar, but hydraulic related. When I was at Ellsworth my hydraulic guys came to me with a hydraulic problem. They told me an aircraft had a hydraulic leak and there was no way they could get to it. I told them, in that case we'll call Davis Monthan Air Force base and send the plane to the boneyard for scrap. With that leak we can no longer fly the plane.
That put it in perspective for them and they got it fixed. But they had to cut out five perfectly good lines to gain access to the leaking one, repair that one, and then repair the five they cut out. All the tubing was titanium, which has no "tweaking" ability. It has to be bent to perfect fit or it won't work. The lines are then connected with special shrink fittings that were stored in liquid nitrogen.
Doug in SW IA
2019 Chevrolet Express 2500 Cargo Van (A55788)
2019 Chevrolet...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2025 Auger Mini Skid Steer Attachment (A55787)
2025 Auger Mini...
2017 TRAVIS BODY & TRAILER END DUMP (A55745)
2017 TRAVIS BODY &...
2005 Kenworth W900 T/A Sleeper Cab Truck Tractor (A55788)
2005 Kenworth W900...
