Good morning!!!!
   / Good morning!!!! #212,083
73F and sunny @ 13:45, calling for a high of around 75F for the day. Low this morning was 51.4F.
Really slow getting rolling. For some reason I was not sleepy last night and couldn't fall asleep, was up until around 06:30 this morning.
Got a couple gallons of water put around the posts yesterday first thing.
Then swapped out the 12" auger bit for the 6" and proceeded to auger what I thought was the short post hole, couldn't figure out why I wasn't getting anything.
Got off the Kubota and took a look ... turns out it was the wrong hole ... 🤬
Tried on the correct hole and had better luck there ... (y)
Then decided to go ahead and drill the post hole for the H-Brace for the southeast corner post using the 6" auger since it's only for a 4 x 4.
Managed to corkscrew the 6" auger all the way in ... 🤬
Spent the entire afternoon trying to get that freed up, including a trip up to the shop for the larger pipe wrench ... which was actually on the desk in the master bedroom ... 🤬
Finally managed to get it unstuck around 06:30. Nothing obvious in the hole that was causing it to corkscrew ... other than dirt being a little more moist, which isn't surprising given the proximity to the septic leach field.
I think the key thing with the smaller auger is to raise it more often, to clear the dirt out of the hole ... so it doesn't bind/grab quite so much.
Tamped down the dirt around the posts before I knocked off and called it a day.
Main item on agenda for today is to move the hay wagon over where the van currently is so I can work on the posts in the shade.
Refuel the Kubota.
Will grab another bucket of dirt while I'm over at the barn to build up around the 2 corner posts.
Probably tamp the dirt around those some more now that the water I put on them has had a good chance to soak in.
Clean up the one post hole I dug yesterday.
Swap out the 6" auger for the 12".
Beyond that just see what else comes up.
Hope everyone is having a decent Wednesday ... (y)
   / Good morning!!!! #212,085
Helloooo Ms. October. :cool:
59F clear sky with steady breeze...another day no rain. :(
Doing chores this morning 4am no problem seeing one's breather :oops: tomorrow morning even chiller.
Good day at work,gave Mrs. wood furnace good cleaning etc. just need spare drive belt,while outside puttering I smelt smoke :unsure: Mrs. decided to give furnace test run.:rolleyes:
Mrs. saw little Boo limping hardly putting any press on left rear leg:eek: if little Boo should show up this evening Mrs. has bunch goodies and BIG fluffy banket waiting for him. :oops:
Plans for the evening...grilling wait for little Boo,bed time will come early out the door 3:30am boss would like me to arrive in Boston before 7am to pick up $$$'s circuit board for much needed machine,try be back before 11AM...new BMW and company credit card.
Enjoy your evening all.
   / Good morning!!!! #212,087
Attended the funeral this morning for my friend, didn't stay for graveside or get together after.
Got truck mostly packed for camping, and camper about ready. Pulled cover off propane and found large wasp nest, quickly sprayed with a can I keep near the shed.
all tires aired up to spec, including truck.
Only electric hookup at state park, so put some water in the tank.
Last night wife and I were discussing maybe selling the camper. 13 years old.
   / Good morning!!!! #212,088
Good (Thursday) morning. Overnight Low of 6.5C and it's presently 13.3C [heading to 15C], lightly overcast with wind. It was a blustery night and there was 3.2mm in the gauge @0900.
A full day yesterday with everything accomplished.
Today is a trip into Launceston for an optometrist appointment... somewhat an annual check-up plus I believe that my prescription has changed (for the better) after quitting smoking last Feb. We'll see, eh? I'll leave in about a half hour.
   / Good morning!!!! #212,089
Good Evening,
Thomas, safe travels tomorrow morning. 🙏
Should have stayed in Vermont. Came home to lights flickering and none of our 220V appliances are working. We realized the problem when we couldn’t get the burners to come on the stove. Went out to the corner of the house and the meter isn’t working either, but we have some lights that are working. Called Eversource and put in a work order. So far they are a no show 🥲
Hope to be straightened out by tomorrow 🙏
Hope all have a good evening 🙏
2008 VIKING TRAILER 40+5 LOADER TRAILER (A58214)
2008 VIKING...
202474 (A54757)
202474 (A54757)
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
HAMM HTC15 TRENCH COMPACTOR (A52709)
HAMM HTC15 TRENCH...
John Deere 1025R (A53317)
John Deere 1025R...
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
