Thoughts on 3pt log splitters?
/ Thoughts on 3pt log splitters? #1
future_vision
Gold Member
New England
DK6010SE HSA
I have been considering getting a log splitter when I heard somewhere about a log splitter as a tractor attachment. Don't know why I didn't think of looking for that earlier. My question is this. Are they worth it? Some of the prices I've seen are on par with a stand alone splitter. I'm wondering if it is worth getting an attachment over a stand alone. Thoughts?
/ Thoughts on 3pt log splitters? #2
I like the idea. No additional motor to maintain...I have been looking for a used one.
Actually it should be pretty easy to make one if you're handy
/ Thoughts on 3pt log splitters? #3
It depends on several factors some of which are:
Cycle times, most tractors are lower flow so splitter runs slow. Need to run tractor full throttle to get rated flow.
Do you need the tractor to move wood while splitting?
How much wood do you split? A pickup load or several loads?
Do you have rear remotes on tractor to supply oil for the splitter?
/ Thoughts on 3pt log splitters? #4
Oldnslo has it. Having remotes and adequate hydraulic flow are the needed items to be a useful tool. My tractor is rated at 11 gpm hydraulic flow and I can run it at 1200 rpms and it works as fast as I want to work. It isn't as noisy as a small engine running wide open.
/ Thoughts on 3pt log splitters? #5
Unless your useing some smaller ram 11gpm is prety slow for a splitter. Also are you sure the 11gpm isnt the total flow?
I have a stand alone splitter. Easier to move, no tractor needed so I dont need to remove anything off my 3pt. You can also find them under $600 in really good shape.
/ Thoughts on 3pt log splitters? #6
I've got a 3 point splitter which I am considering selling. It has a hydraulic pump driven by the PTO. Where in New England are you located?
/ Thoughts on 3pt log splitters? #7
A tractor is way too handy at bringing rounds to a splitter and stacking the splits off of the splitter into the bucket.
Putting hours on and tying up your tractor for what a $500 motor can do is just stupid if you think about it.
The firewood needs "wheels and a bucket" on it, not a splitter.👍
Small engines run and start easily with the slightest bit of maintenance and care. (cover it, treat your fuel and change the 1 quart of oil in it every 40 hours)
/ Thoughts on 3pt log splitters? #8
If you are splitting near your home or pole barn, consider an electric splitter. No noisy engine, no fuel, no oil changes and there are models that handle up to 20 tons.
This is the one I nearly bought:
I decided to get a processor instead.
/ Thoughts on 3pt log splitters? #9
I had one that my father built, which I ran off my BH pump. Then I inherited his stand alone and won't go back. As someone else suggested I fill the bucket or grapple, pull up close so that I can roll them off and toss the splits into my dump trailer. I pick really big pieces up in the grapple, lower them and slide the splitter underneath. Once it gets to manageable sizes I will move the tractor (or splitter) away.
/ Thoughts on 3pt log splitters? #11
I really like mine but most people prefer a standalone. I've had mine almost 15 years and done zero maintenance. Storing it in the barn takes very little space. I do all my splitting at the woodshed so no other use for the tractor. I don't have much hydraulic flow but it's a two way splitter ( hard to find now) so it's fast enough for me.
/ Thoughts on 3pt log splitters? #12
I have a Tool Tuff 3 point log splitter that is run off of the tractor hydraulics. Its based off of a 22 ton model. It depends on what your doing with it. I do not heat with wood, so I use it to split larger pieces so I can load them by hand into friends trucks.
  • It is sloow compared to a normal 22 ton splitter. 1/2" Pioneer quick couplers are only good to 12 GPM so I cannot run the full 20 GPM my tractor is rated for. I think it would be much more tolerable at 20 GPM.
  • The tractor takes up lots of room so you have to park a truck or trailer 90 degrees to it.
  • It makes the tractor long, and therefor harder to navigate through the woods.
  • I am running a 45 hp diesel engine vs a smaller gas engine, It would be more economical to run the gas engine.
  • It ties up the tractor as I cannot be using the tractor to load split wood, or bring pieces to the splitter.
  • It is one less engine to maintain
  • It is easy to store as I just set it on the crate I made for the post hole digger.
  • It is reliable. If I do not use it for months I have no issue as the tractor is used all the time and will start.
  • You can back the tractor and splitter right up to large rounds so you only have to move them inches.
For my limited use its great and way better than a stand alone unit. I am an infrequent user and a stand alone unit would always need work. There is very little to go wrong. The tractor engine at 1000 RPM is quiet, it is plenty strong too. If you are splitting more than a cord a year I would get a stand alone. If your splitting less then a cord a year then a tractor mounted unit is great.
/ Thoughts on 3pt log splitters? #13
I got a 3 point splitter and at some point I would like a PTO pump to run it.
Then I could overdrive it off the PTO and be able run the tractor at just above an idle and still have high flow rate.
/ Thoughts on 3pt log splitters? #14
Put me down for a stand alone vote as well. I was dead set on doing a PTO splitter. but I asked a similar question and got similar answers. Found a 22 ton with a dead engine for a good price, put a $99 predator on it, added a little side table to aid in splitting bigger rounds and it has been flawless. Poor thing has sat out in the weather for 6 years and does everything I ask of it without a single complaint.
/ Thoughts on 3pt log splitters? #15
I thought of a 3PH log splitter and found out that the GPM were so low on my tractor splitter would be slower than a stand alone... And I didn't have Power Beyond (PB) to power splitter
Also if tractor/splitter is tied down at splitting pile, I can not use it to actually move the rounds I need to spit (old age and cardiac conditions)
Found a 30 year old used 22 ton with broken 5 hp B&S motor, searching for replace parts I realized I could buy a new motor from HF (6.5 hp) for less than fixing the B&S.... And form factor was same for pump side and everything bolted up...
Bought some new hoses and replaced hydraulic filter.... New wheels and tires...
Best overall $550 ever spent....
IF you have small tractor, hydraulics may have low GPM, then to get anything done you may need a PTO driven pump and a reservoir... So you are almost to a point of a standalone...
/ Thoughts on 3pt log splitters? #16
I store and move my firewood in log form until it gets split right in front of the wood shed. Having the tractor move log length wood to the splitter that's 8' from where it's going to be stacked means I handle it a bit less.
I burn 4-5cords of hardwood a year. And will have a fire going for 4-5 months non stop.
I did build a large 35t splitter with 15hp engine but found it hard to move. Having a stand alone one you can easily move is nice.
In my case this would be hooked up to a 60hp tractor and I would use my UTV to move the cut wood around. Might even get a little trailer for it. As for amount of wood, I cleared a few acres and have a lot of hard wood to split but I don't see doing much more than that going forward. Maybe if we clear more of the land.
I have a 60HP tractor with rear remotes. The flow is enough to run a serious wood chipper. I am basically looking to split a lot of wood from a 2-3 acre lot. After that it might be the occassional log unless we clear some more land. Predominantly hardwood although I have a large amount of pine too which I am still debating about. As for moving it around I have a small UTV but I would really like to get some IBC cages and use my forks. I just need to find some inexpensive IBC cages.
/ Thoughts on 3pt log splitters? #19
The IBC cages are amazing for wood storage. I have 5 or 6 that I cycle through. I just toss the wood in, don't really sweat stacking it well. But I am in Tennessee so I don't burn as much as you yankees. If I burned 5 cords I might try to squeeze for into each cage. It just makes it so much less work to toss it straight from the splitter into the tote and not have to touch it again until it goes in the stove. I was lucky enough to find a guy selling the cages without the plastic bladders. It has been years now, but I think I paid $20 a piece, in hindsight I would have paid more as convenient as they are. I made a little roof for the one I am actively using at the house that can hinge open for ease of use.
/ Thoughts on 3pt log splitters? #20
I have a 60HP tractor with rear remotes. The flow is enough to run a serious wood chipper. I am basically looking to split a lot of wood from a 2-3 acre lot. After that it might be the occassional log unless we clear some more land. Predominantly hardwood although I have a large amount of pine too which I am still debating about. As for moving it around I have a small UTV but I would really like to get some IBC cages and use my forks. I just need to find some inexpensive IBC totes.
If you want to use IBC totes and forks on loader would you want the tractor tied up on the splitter?
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
Unused 2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2015 CATERPILLAR 525D DUAL ARCH GRAPPLE SKIDDER (A65056)
2015 CATERPILLAR...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A66736)
2015 International...
