Calling for help! Trying to find why air keeps entering my hydraulics.
   / Calling for help! Trying to find why air keeps entering my hydraulics. #1
dsebens
1973 Ford 3400
I keep having air enter my dump side of the bucket hydraulics. This fitting is a swivel fitting and is loose when no pressure, it is the same on both sides. I thought maybe it was the spool orings in the valve as there was seeping there but I replaced them and thats no longer an issue. Can these types of fittings leak air into it when they are not under pressure? I have never seen any fluid come out of them. I have replaced the lower ones as the rubber was breaking off the hose but havent replaced these. Also if this could be the fault, these are not resealable right? I assume I can put new orings in?
I verified it is an air issue as when I take off the hose there is an air gap in the hose and top of cylinder. It causes the bucket to kind of float when lowering onto the ground, I have to "preload" it down then go back up once it engages the pile otherwise it will try to pull it down. You can also tell it is an air issue as I can stall the hydraulics instantly when maxed out the other way but dropping the bucket has to compress an air spring before it stalls the hydraulics.
   / Calling for help! Trying to find why air keeps entering my hydraulics. #2
Sounds like the typical floppy bucket syndrome experienced on some models of tractors and loaders. What is happening is that the load causes the dump cylinders to extend faster than the oil supply can fill the blind end of the cylinders. This creates a vacuum - air pocket in the blind end of the cylinders. One cure is to put a flow restriction on the rod end line for dump cylinders so you get a more positive power dump. Another is a valve that has regenerative dump feature. This directs the flow exiting the rod end back into the blind end. Gives you faster dump speed with minimal chance for floppy bucket.
My loader has single dump cylinder so I installed a counterbalance or over center valve. This allows smooth consistent dumping at all speeds since it requires a positive pressure in the blind end for the valve to open allowing it to extend. Very helpful when using forks and trying to feather the tilt.
Hopefully this all makes sense.
That does make sense which is why I think if I fix any air leaks I think it would be better? The loader valves are kind of a high gpm but I don’t want to replace it if I don’t have to. This valve doesn’t have a float either. I would love to have that but not if I don’t have to replace it.
   / Calling for help! Trying to find why air keeps entering my hydraulics. #4
I doubt that you have an air leak causing this problem and there are no seals in the directional valve that would leak and allow air into the dump circuit. The only seals onna directional valve are on the ends of the spool preventing the tank line oil from leaking out. A system air leak would most likely affect all of the other functions.
An oversize valve might make the floppy bucket worse since will pass even more flow and allow bucket to dump even faster creating a bigger vacuum.
As a simple experiment try feathering the dump so it dumps slowly and see if still have the problem of air pocket. If no this is similar to restriction in rod end controlling how fast the bucket can dump.
Going slow didnt change it. It turns out you are right and it was drawing a vacuum. I dont think going slow is a valid test as it is still restricting flow evenly on the spools. I got those cheap restrictors from the farm store and they fixed the issue but I need to drill them out. I think the hydraulics on the tractor are 12gpm and the 1/32 hole is too small. I have one on each cylinder and it makes the hydraulics cry quite a bit but there is no flop. I need to pull up an orifice flow chart to estimate sizes but I am going to start by doubling the holes up to 1/16 and then will keep testing up until theres a good balance of speed and not over straining the hydraulics. I am hoping that I will stop at fine and not chase perfection to end up right where I was to start with!
Well I decided 1/32 sounded tiny and the logical next step of 1/16” sounded tiny also so I went with 1/8”. Well it’s better than it was but there is still not enough restriction. It will still happen if I don’t run full flow through the spool. The flop is much less now though.
I figured I’d never know how big is too big unless I tried. I’m going to remove both orifices from the cylinders and put one of the 1/8” drilled orifices before the tee. Looking at the area .0625 is .003 sq inches, .125 is .012sq inches. That’s quite an increase. I think putting one in the main supply should be a good comprise. If not it’s easy enough to keep tuning it.
Well hopefully my final update for this issue. I decided to move them as I said. That seems to be a good compromise. If I have the tractor rpms up and give it full stick you can hear the fluid really squirting in the restrictor but under normal movement you wouldnt notice it there and it seems to have fixed the problem.
I am not going to lie @oldnslo I thought there is no way you were right but it was for sure a vacuum. Probably has to do with the cross valve being rated for 30gpm and also the bucket on the 730 is a big bucket compared to many older loaders of the time period. Thanks!
LOT: Assorted Vise Grips (A59076)
LOT: Assorted Vise...
2018 CATERPILLAR GRAPPLE RAKE (A58374)
2018 CATERPILLAR...
Hydraulic Breaker Excavator Attachment (A55973)
Hydraulic Breaker...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
1987 International S1900 Fuel Truck (A55272)
1987 International...
