Friend with GMC 5.3 problem.
/ Friend with GMC 5.3 problem. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I have a friend with a GMC pickup with a 5.3 engine, 55,000 miles. It’s a 2017. He called and then stopped by, said he had a ticking sound. Yes it’s pretty distinct and I listened around with mechanics stethoscope and it was loudest on cylinder number 6, passenger side, when held to the exhaust manifold.
The first thing I asked was does it drop down to 4 cylinders, yes it does. I knew they could be problematic. He took it to a local mechanic who is busy and said it’s not good and take it to the dealer. The dealer said we see this a lot, it probably has a valve spring in a bind and a bent push rod. They are tearing into it. Worse case it might need a cam.
My question is I know they make something you can plug into the OBD port and turn off the cylinder deactivation. Do these work well and do they help eliminate future problems?
/ Friend with GMC 5.3 problem. #2
One product is "Range",we installed one in my son's 5.3 two years ago;they do what advertised.He hasn't had any problems.Cost about $200.Only problem there is a slight electrical draw,not a problem if you drive regular.
/ Friend with GMC 5.3 problem. #3
For local driving, I shift into M5 (older 6 speed) which keeps in 8 cyl mode all the time.
edit: I also have a Range and it works as advertised. I normally have it off as it does draw power as you say.
An update. The dealer tore into his truck already, the mechanic didn’t mess around. Bent push rod, he said the lifter was probably bad also. He will replace the 4 lifters that work on that bank and are the AFM cylinders. He will also replace the part that controls the cylinder deactivation which I think sits in the valley between banks. You could tell this wasn’t this mechanics first rodeo in fixing this problem.
In my first post I said a valve spring in a bind, it’s actually a spring at the top of the AFM lifter that binds and bends the lifter.
/ Friend with GMC 5.3 problem. #5
I put the Range dongle on my Suburban last December, and it's worked perfectly so far. Didn't notice any difference in performance or gas mileage.
/ Friend with GMC 5.3 problem. #6
I bought and plugged in a Ranger on my Silverado 5.3 in 2013 when it was new, only time it has been removed is just before i turn off the engine at the dealers. Today it has 88K on the odometer and has that ticking sound. Took it to the dealers; service manager said that's normal for that many miles; then said my oil pan gasket is leaking, and that's normal for the mileage, $3,000 to replace the oil pan gasket. I told him NO! I'll just keep adding oil, it's way much less money
/ Friend with GMC 5.3 problem. #7
My Colorado doesn't have anything like that and at 128k it's got a definite valve tick. I've changed the oil religously and expect a well maintained engine to easily go 200k+ miles.
/ Friend with GMC 5.3 problem. #8
The OBD DOD/AFM disablers work. I have on my 2014 Denali with 240k on it. It is absolutely worth it. That cylinder deactivation has been a problem since it came out in 2008. Even after disabling the AFM my fuel mileage only dropped about by about 1 1/2 miles per gallon.
A picture from the internet of the AFM lifters on deactivated cylinders. It’s the spring at the top of the lifter that binds and bends the push rod not the actual valve spring.
/ Friend with GMC 5.3 problem. #10
$3K to change an oil pan gasket?
Do they have to pull the engine to do it?
I think I have seen YT videos changing it it a few hours.
/ Friend with GMC 5.3 problem. #11
Ya, the local GM dealership service dept. said the motor had to be raised up about 4" to remove the oil pan.
BUT, they also said it was leaking at the oil filter mount; this mount is machined into the pan LR corner.
When I got home I put the truck on ramps and checked tightness of pan bolts; all were quite loose according to my ¼" snap-on torque wrench. The 2 bolts below the rear main were finger-tight.
I asked the dealer why the inspecting tech did't find those loose bolts, he replied "well the tech would have discovered them when he began to remove the pan". That's when I loudly said BS! and told him motor oil is cheap by comparison.
I'm still hung up on him saying the 5.3 normally begins leaking oil around 80K miles.
I thought about pursuing this and ask for the GM, but I felt my BP rising already, and I used to have a short fuse anyway.
/ Friend with GMC 5.3 problem. #12
I'm at 106,000 miles on my 5.3L 2016 Sierra. No leaks or engine valve ticking.
Post warranty, I avoid the stealerships, in favor of smaller, local shops.
/ Friend with GMC 5.3 problem. #13
I have a 2013 silverado with a 5.3 and 151000 miles. No tick no oil leaks. I have used marvel mistory oil a bunch of times and shift to M5 .
/ Friend with GMC 5.3 problem. #14
Bought one of the cheaper Amazon versions of the range and installed it on my wife's 2011 GMC Yukon Denali with the 6.2 and when we traded it in last year it had over 250k on it and not 1 problem with the motor, I am convinced shutting off AFM is a good thing, I used a Flashpaq tuner to turn it off via the trucks computer on my 2012 Silverado with a 5.3.
/ Friend with GMC 5.3 problem. #17
I’ve been told they reduce the occurrence of lifter issues, but don’t eliminate em.
If he’s gonna have the top end off the motor, I’d get an AFM delete kit-cam and lifters and be done with it.
/ Friend with GMC 5.3 problem. #18
Where's @5030
He loves talking about this topic.
It's not like him to be absent for so long...
/ Friend with GMC 5.3 problem. #19
Where's @5030
You're right, I haven't seen him clogging up threads for a while. Maybe he got banned here to. He got kicked off OTT a while back.
New Holland T5 120 Tractor (A64047)
New Holland T5 120...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
UNUSED RAYTREE RPRB72-72" HYD POWER RAKE BUCKET (A62131)
UNUSED RAYTREE...
2022 KOMATSU PC130-7 EXCAVATOR (A62129)
2022 KOMATSU...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
