Ford 7610 hydraulic newby
/ Ford 7610 hydraulic newby #21
You're missing the point. The purpose of the flow meter is to measure the output flow at rated pressure, not just free flowing fluid into a bucket. Most any pump can fill a bucket.
Adding more oil is to see if that will keep the pump primed on a hill to possibly trouble shoot the pickup tube, not the condition of the pump.
Could I not say the same to you? Low flow would not give no flow when on a hill but poor pickup might?
I mean that tongue and cheek šŸ˜ as I appreciate one still needs good flow at load to operate any hydraulic system correctly.
I dont have nor can I get access to a flow meter so it will have to wait but will try to source one so we can test it.
I really do appreciate your input and am learning alot here.
/ Ford 7610 hydraulic newby #23
Not exactly a true flow meter, but if you use the "hose into a bucket" method with some sort of an orifice (or a nearly closed valve), it will give you a pretty good indication of flow under pressure.
/ Ford 7610 hydraulic newby #24
It will also spray a lot oil under pressure all over the place. If that's your idea a "homeowner" test, then go for it, but I wouldn't be suggesting it to some unsuspecting individual.
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
1998 POLAR TANK (A60736)
1998 POLAR TANK...
FIFTH WHEEL ATTACHMENT PLATE (A60736)
FIFTH WHEEL...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
