Kohler 26hp twin surging at high throttle, okay at medium to 70% throttle
   / Kohler 26hp twin surging at high throttle, okay at medium to 70% throttle
This may be helpful for you. I see they have the Command carb at the bottom which shows a model w/ an accelerator pump but hopefully similar enough to get the idea how it works. Typically a surge that goes away under load is considered a low speed circuit issue as Randy has pointed out. Consider too that intake gaskets and seals can play a part as well. https://outdoorpowerinfo.com/repairs/#id_kohler
I'm reading through the carb details re the Command carb - what a great write up. Part of me was planning to go back to my Original carb and make sure everything was clean and set correctly, (which I may do shortly), but it occurred to me that the new carb on there ---- maybe it just needs the idle fuel mixture adjusting screw adjusted.... Gonna try that and if no improvement, then go recondition original carb.
   / Kohler 26hp twin surging at high throttle, okay at medium to 70% throttle #22
You might find too that a Kawasaki carb looks closer to what you have. In any event, that site has put some real effort into how carburetors function. Admittedly I am not fan of jungle carbs. But, no one is a fan of much of the Kohler carb pricing. I mean some of these things are 450$
Thank you, as always Tom. And the others that helped here. I went through and really cleaned the original carb, pirated a couple bits off the new, and now machine runs smooooooth!!! Thanks so much.
1998 NATIONAL TRAILER (A55745)
1998 NATIONAL...
2019 Chevrolet Suburban SUV (A55758)
2019 Chevrolet...
New Swict 66" Skidloader Bucket (A50775)
New Swict 66"...
2014 Ford F-150 Pickup Truck (A55788)
2014 Ford F-150...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55302)
2022 John Deere...
UNUSED FUTURE QST 43" MINI HYD BROOM (A54757)
UNUSED FUTURE QST...
