Boosting hydraulic pressure
/ Boosting hydraulic pressure #1
y112
Danville PA
620 John Deere, (1) 318 JD, 425 AWS JD, 4500 JD
I have a 620 John Deere with a Bush Hog 3pt hitch log splitter. The splitter works generally well until I get into some big oak. Then the hydraulic squeals on the tractor and I have to knock the wood off the splitter wedge. I've been told the cylinder is big enough but the pressure relief valve on the tractor is releasing. Has anyone ever shimmed up the pressure relief valve on a '58-59 620 John Deere? I have a repair manual but was hoping someone had done it before.
/ Boosting hydraulic pressure #2
No doubt the pressure is too low for the log splitter at 1200 psi, but increasing the pressure of the tractor will shorten the life of the pump or cause irreparable damage. I would be inclined to attach a PTO pump and reservoir for the splitter. The splitter valve most likely has a relief in the 2000-2500 psi range that will protect the system and deliver the results you desire.
/ Boosting hydraulic pressure #3
IF you tractor hydraulic pressure is only 1200 PSI and splitter cylinder id is 4 inches you are only getting about 7.5 ton ram pressure...(you only care about push pressure)...
Even increasing pressure to 2000 PSI will only give you about 12.5 ton....
Most stand alone splitters with only 6.5 hp motors can develop 22 tons... I do primarily oak wood and my 22 ton splitter has to strain on some.... Would not consider anything less in tonnage (22 ton) unless it is really softwoods....
Appreciate your reply. The JD service manual shows how to add shims to increase pressure. I've never had it apart and it's externally accessible. I see you have Ford tractors and was hoping to get a reply from someone that has worked on these JD tractors. The old knowledge base is getting thin. Your PTO idea is interesting, but would the pto pump, near idle, make enough pressure to run the splitter? That 2 cylinder can idle at 500 rpm
View attachment 4080647...
I'll check the JD manual to determine the pressure. If it turns out to be less than the splitter, I might have to mount a gas engine and separate pump. I do have a Kawasaki "650D twin" engine off my mower that should work. What size pump should i get to run the splitter?. I get stuff from Northern Equipment
/ Boosting hydraulic pressure #8
Safest way to increase the force without harming the old low pressure system in that Deere is to mount a larger diameter cylinder to the splitter. Just going from a 4”to 5” diameter cylinder would increase the force from ~15000lbs to about ~23500lbs which is over a 50% increase. Only drawback is it would slow the cyl stroke time by about 50% also, if that matters to you.
/ Boosting hydraulic pressure #10
My knowledge is old and broad, not just Fords. I may not know the old JDs inside and out, but the hydraulic system in those are basic gear pumps.
One thing no one has mentioned, whenever you adjust pumps, you need to have a pressure guage to determine what pressure the relief is opening.
Your pressure may be low anyway being it is an old tractor, but it wasn't made to operate at the higher pressures that today's hydraulics ooerate.
Midifiying your splitter by adding an engine would be the best
Depending on how I hooked up the hoses, it would travel normal speed or very slow. Do you think the "slow" hookup had more pressure?
/ Boosting hydraulic pressure #13
Could the tractor reservoir be utilized for the external pump, using the tractor hose couplers, or wouldn't it draw oil through the tractor pump?
Personally I don't think you can draw through tractor pump without tractor running , you are going to use log splitter pump I would try to tap the reservoir directly and keep "tractor system" (pump) out of the arrangement....
/ Boosting hydraulic pressure #14
No you cannot draw oil through the pump and couplers on you tractor.
/ Boosting hydraulic pressure #15
No , you’re relief valve setting will always be your high pressure limit. With the same gallons per minute flow the retract side of cyl will be faster than extend side. This is because the cylinder rod is taking up space on retract side and creating a smaller cavity to fill.
/ Boosting hydraulic pressure #16
Just keep in mind that you would be adding an engine, pump, tank, filter, and possibly valve, plus a bunch of hoses and fittings. So essentially building most of a log splitter. You could probably buy a stand alone splitter for the same or less $$, and a lot less work.
As for your existing setup, I would first get a gauge on the hydraulics and see what pressure you are reaching vs the tractor specs. As earlier suggested, the pressure may be low relative to specs, and bringing it up to spec will improve performance. I would not increase it any more than 10-15% over spec, and I'd think twice about doing even that. Any tractor damage caused by the higher pressure may be difficult and expensive to fix on an older tractor with limited parts availability, etc.
Also as suggested earlier, the easiest "fix" is to increase the cylinder size. That would be a pretty easy and affordable swap. The down size is that the splitter will run slower, so you are trading time for splitting power.
If you are going to change to some other source of hydraulic power, whether driven by a separate engine or a PTO driven pump, I would carefully compare the costs vs buying a stand-alone splitter. I think you would be hard pressed to build a hydraulic system and pump for less than a purchased splitter. Hydraulic hoses alone will cost $50 to $200 each depending on size and pressure rating. And you would need to carefully figure out the flow, pressures and splitting force. including whether or not to use a 2 stage pump.
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
2025 Hydraulic Drum Mulcher Mini Skid Steer Attachment (A61567)
2025 Hydraulic...
2001 T/A 20FT Enclosed Trailer (A61569)
2001 T/A 20FT...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2018 FREIGHTLINER...
PROPANE TANK CAGE (A62131)
PROPANE TANK CAGE...
UNUSED WOLVERINE TF1-66-4000G-66" PALLET FORKS (A62131)
UNUSED WOLVERINE...
