Kubota subframe kit wanted
/ Kubota subframe kit wanted #1
DiggerRick
Butler, PA
L2800
I'm looking for a Kubota BH4976A Backhoe Subframe kit with seat and hydraulic hose. Its for a BH76 Hoe mounted on a L2800 Tractor. Its old stock, so if you have one laying around, I'm interested in it. Does anyone know if there are any after market ones out there or is OEM Kubota the only one that will work with this set up.
/ Kubota subframe kit wanted #2
I’d suggest contacting a local kubota dealer for availability and pricing. I doubt there are other options but I could be mistaken. Last year I sourced the subframe for my b3300 and bh76. It was just under 2000 cdn, or 1300 us but each tractor has a specific subframe that varies between 1000 to 2000.
I was able to find the kit through a local dealer. It was ordered through Kubota for about $850. Currently installing it- the dealer wanted $1000 to install, I have about 3 hours into it as a novice and just need to install the hoses and seat to finish. Its crazy how everything has shot up in price lately and this install did not look that complicated. The instructions were confusing, but using common sense, it went together very easily. Thanks for all the input- Digger
/ Kubota subframe kit wanted #6
Are you talking about the links to the tractor profiles? Those, for better or worse, are added by TBN.
I think some tractor models automatically create links- L3301 L2601 CK2610 BX2380
[EDIT]: None of those.
Not those, the last link (which have been deleted) on the original post (which is also deleted). Something to the effect of AARP and some other crap...
AI will respond to the question but add a link that could upload malware to your computer without you knowing... if you click on the link.
/ Kubota subframe kit wanted #7
Oh wow, that was taken care of before I arrived- good on the report. What I find amusing is that the tractor models I posted, that didn't initially get a link, well- some now do.
JOHN DEERE HX14 - 14' ROTARY MOWER (A64276)
JOHN DEERE HX14 -...
New/Unused Wolverine Sickle Bar Mower (A65583)
New/Unused...
2019 Nissan Maxima Sedan (A61574)
2019 Nissan Maxima...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
