Worlds most powerful 1210 Ford FWD?
   / Worlds most powerful 1210 Ford FWD? #31
this is an old post but worth a shot... i was considering doing some modifications like you mention. Can you shed some light on where this smoke screw adjustment is on the injection pump and which way you should turn it for more fueling?
Thanks!
He posted here too.
https://www.tractorforum.com/threads/turbocharge-your-ford-1210.63117/
The turbos are from IHI.
Shibaura Turbos
For the Ford 1000 series machines, this should work.
   / Worlds most powerful 1210 Ford FWD? #32
He posted here too.
Shibaura Turbos
Thanks, i took a look at that other link, i still didnt see anything in there regarding the procedure for fueling adjustment in the injection pump.
Are you familiar with these tractors and their shibaura engines? I have not been able to find any information regarding how to adjust the fuel in the injection pump. I read through all of the manuals i have for the tractor but still didnt find anything. I am pretty good with diesel mechanics, but on older diesel truck engines like a 12 valve cummins or 7.3 IDI engine. I kinda feel like this Ford 1210 injection pump has a similar situation as the IDI, where youd remove an inspection plate somewhere on the injection pump and find an adjustment screw inside of the pump, but i also dont want to start tearing things apart on the pump without at least some information on what to look for.
Let me know if you know anything!
thanks
   / Worlds most powerful 1210 Ford FWD? #33
You might want to contact the @thepumpguysc who is a member here on the forum. He rebuilds pumps and can steer you in the right direction.
   / Worlds most powerful 1210 Ford FWD? #34
how do i send him a message? when i click on his name i cant find anything that allows me to personally message him...
   / Worlds most powerful 1210 Ford FWD? #35
Private Message him see attached pic.
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55314)
PENDING SELLER...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
EZ-GO Electric Golf Cart (A55853)
EZ-GO Electric...
