Kubota hydrostat fluid out of the breather
   / Kubota hydrostat fluid out of the breather #1
Steelphoenix
Masontown, Pa
L3710 Grand Kubota
I have a 2000 L3710 Grand HST that suddenly started blowing all of the fluid out of the transmission breather. I mean it pours out. Everything, FEL and PTOs and drive work fine.
I changed the hydro filter and that didn't help. I did recently change all of the loader lines but that was 10 hours runtime ago.
Tractor has 780 hrs. on it.
Any help would be greatly appreciated!
   / Kubota hydrostat fluid out of the breather #2
Does the oil look foamy or is it pretty much clear oil?
Did you recently remount the fel or any other changes to hydraulic circuit before this happened?
   / Kubota hydrostat fluid out of the breather #3
I'm suspecting a couple of issues.
I'd look at possibly the relief valve stuck closed.
But it might just be overfilling of the hydraulic system since you recently worked on it.
The oil is clear and it just runs out of the hydrostat breather until its empty. I did change the FEL hoses but it worked fine for 10 hrs. After the problem started I changed the filter but no help.
I can rule out overfilled as it just empties the system. Which relief valve are you referring to?
   / Kubota hydrostat fluid out of the breather #6
It should be on the pump housing.
Here is an example on a different Kubota tractor.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
2013 Nissan Juke SUV (A55853)
2013 Nissan Juke...
