Yanmar SB60R Front End Snow Blower
   / Yanmar SB60R Front End Snow Blower #1
Baughes
Montana
2023 Yanmar SA425
I just wanted to say my Yanmar SB60R snowblower, attached to my Yanmar 425 performed like a champ this winter. I live in Montana and we had a light winter compaired to most years but when it snowed. it was in feet and usually multiple. The blizzard of January 17, 2024 I plowed 4 1/2 miles, 3 times to keep the road open for my wife's birthday party. The SB60R handled everything. It throws snow about 30 feet off the road so we don't get the narrowing we have had in the past with my old JD.
The chute turns quickly and has a wide swing that allows perfect placement of the snow. I loved the reverse PTO Kill switch that allows you to back up without having to turn off the PTO. I was concerned with it's reliability when I bought it but was told it would be perfect for my needs. It lived up to its recommendation. It attaches and comes off the tractor quickly so I could use the loader/grapple when I needed it for tree removal. I have to say I am extreamly pleased with how well it performed. Not one issue this winter. Looking forward to next winter's snow removal.
   / Yanmar SB60R Front End Snow Blower #2
Is your Yanmar a YT425, EF425, AF425 or the tiny SA425? The prefix really matters.
   / Yanmar SB60R Front End Snow Blower #4
Its the tiny SA425.
Even as it's a small CUT, the SA425 has the largest for the rear wheels. The smaller SA models can't use a PHD due to the really small rear wheels.
   / Yanmar SB60R Front End Snow Blower #5
Hey Op,
what part of MT are you in and what dealer are you using?
I am in Bigfork, and am using Glacier Supply in Bigfork. If there is anything that I can buy online I am using Deer Mountain Equipment in Washington St. They are resonable, fast delivery, care about you and are on time.
   / Yanmar SB60R Front End Snow Blower #7
How is that blower mounted and driven? Is it PTO driven, or hydraulic, or something else? Thanks for the good report. I live in the mountains of Utah. I have a rear mounted PTO driven blower and it performs quite well, but it's a literal pain in the next. I'm looking for ideas on a front mounted blower.
   / Yanmar SB60R Front End Snow Blower #8
I realize this is an old post, but I have a question on the Yanmar SB60R blower on a SA425 and this seems like the most relevant writeup I've seen so far. I just hooked up the snowblower for the first time (all new) and the long driveshaft from the Mid PTO to the bearing in the blowers frame assembly seems to have a pretty good wobble. Everything works fine, but the wobble appears to be more than I would expect. I checked all the mountings, the bearing and there doesn't seem to be any excessive play anywhere. I am starting to think that maybe the shaft isn't perfectly straight, but before I go back to the dealer or have it balanced, I was wondering what others have seen. Thanks for any observation out there.
   / Yanmar SB60R Front End Snow Blower #9
Sounds like a good set up. I'm new here and BEFORE I buy am wondering how long it takes to shift from Front Loader to Snow Blower on a Case 55C... I'll be interested to see responses to your post.
   / Yanmar SB60R Front End Snow Blower #10
Does the drive shaft slide apart? If yes have you confirmed the phase angle of U-joints is correct? Most shafts only fit together one way but I have read reports on some that allowed assembly in more than orientation.
T-POST PULLER (A52708)
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
Club Car Utility Cart (A55851)
Club Car Utility...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
Online Buyers Premium (A55272)
Online Buyers...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
