Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #25,431
   / Tractors and wood! Show your pics #25,432
Pile is looking good. Doesn't look like you have much of a problem with pine weevil where you are ??? How about blister rust ?? We have both here and pine does not fair well.
gg
I have seen no sign of either. With 50 acres of woodland that’s mostly pine, I’m thankful for that.
   / Tractors and wood! Show your pics #25,433
Weevil very common here. Open growing trees especially vulnerable like fields. Tighter forested areas less so.
   / Tractors and wood! Show your pics #25,435
Last July on a quiet sunny day we had a power failure when a couple of trees decided it was time to fall. They broke the hot wire on top and came to rest on the ground wire which held. The power crew cut the trees in random short lengths and left them on the side of the road. I finally went out to pick them up today. I needed them out of the way for fall mowing.
The ratty Hop-Hornbeam or locally Ironwood is in the right side of the trailer the rest is Red Maple.
Since I had to move it, I thought that I might as well bring it home - 1/2 mile down the road - and run it through the wood stove.
gg
   / Tractors and wood! Show your pics #25,437
^^ yikes did he see the bottom of your boot?
   / Tractors and wood! Show your pics #25,439
Had a visitor while cleaning up a deadfall I had cut up last fall. Another reason to wear gloves while working.View attachment 4002066
You get those up in IN, too? I see them very occasionally here in recent years, but they're not very common this far north.
   / Tractors and wood! Show your pics #25,440
So what is that thing - never saw anything like that. I guess I should be glad from the sounds.
gg
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A55787)
2025 JMR 72in Dual...
2013 UTILITY VS2DX DRY VAN TRAILER (A54607)
2013 UTILITY VS2DX...
2018 FORD F150 XL TRUCK (A51406)
2018 FORD F150 XL...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
378811 (A51573)
378811 (A51573)
2014 PETERBILT 386 DAY CAB (A54607)
2014 PETERBILT 386...
