10’ snow pusher
   / 10’ snow pusher #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
Anyone using a 10 footer on their tractor?
If so, what is the machine and where you are would be helpful to gage type of snow.
   / 10’ snow pusher #2
102" pusher here (18" short of 10') on a 5 ton SS and chains on each corner.
So much depends on snow consistency and your use. That "use" would be commercially clearing a parking lots continuously after a certain depth or accumulation or a more residential, end of snow clearing.
Obviously it's better to "plow with the storm" as Fisher plows old saying said, but I find most snows here of any respectable depths (18-20") are usually a dry consistency and plow/push easily with the above machine.
Weight, inertia and traction, are your friends with a pusher box particularly with longer parking lot runs.
   / 10’ snow pusher #3
Mine is a snow blade, its a 8', I am in Northern Ontario Canada it is quick connect and has hydraulic angles (tilt)... I have a 60hp tractor @ 3 to 4000 lbs with loaded rear tires and snow blower in the back and to effectively use the tilt in heavy snow I would need snow chains on all 4 but straight its pretty good still pretty heavy since its so extended up front.
   / 10’ snow pusher #4
I am, yes.
Massey Ferguson 7495
Pennsylvania
I fabbed-up a Western Heavyweight from a large dump truck to work off my front 3-point hitch.
Added a crossover relief valve.
   / 10’ snow pusher
102" here (18" short of 10') on a 5 ton SS and chains on each corner.
Thanks Rusty
Have a customer who wants to do commercial work and has asked if the Mahindra 6065 ( largest we carry) will push a 10 foot. This tractor is around three ton dry and I can get it up to around five ton with fel and loaded tires.
We get storms of the slushy type and to me, 8” of slush type is equal to 24” of dry.
I have no experience with pushers more than 7’ hence my reach out to the more experienced.
   / 10’ snow pusher
   / 10’ snow pusher #7
See what your customers contractual conditions are.
I think that much of the commercial work in today's litigious society, commercial customers are requiring constant operations. Once a predetermined depth or other requirement is met and plowing operations commence with xx equipment operating continuously until some other (contractual) condition is satisfied.
In English 😉, he might have to scrape every 2,3-4" and 10" of sloppy wet snow is not a concern. Then there's always taking less than full passes.👍
   / 10’ snow pusher
This leans to more of “if there’s a will, there’s a way”.
Got me thinking in a different direction so thanks for that Rusty.
10’ is a lot of load collected so naturally my thoughts went to dimensional capacity coupled with volume of snow and type and figuring weight of tractor in the equation.
That doesn’t always necessarily hold water..or in this case snow.
If we had tractors the size of Hay Dudes, all I would need is to figure is cost of the tractor.
   / 10’ snow pusher #9
I have been watching tractors of all sizes and frequently see 100+ HP tractors sell for less than new pint-sized 35HP compact tractors.
I would encourage any TBN member looking to push snow or mow fields to look at older and bigger AGCO, NH, Deere models which will dwarf the little compacts guys spend $40,000 on.
I passed up on a 15,000LB Challenger MT545B (140HP) with a CVT transmission and loader. It was in nice condition had 5,000 hours on it, lots of great features and sold for $42,000.
I should have bought it.
Here’s a great example of what I am saying. 110 HP, Cab HVAC, great tires, low hours. Asking $28,500. Probably sell for 25K. You could start a field mowing and snow plowing business with that tractor.
   / 10’ snow pusher #10
What's going on is that 80-120 H.P. tractors are too small for large farm operations and too big for the average small acreage/home owner type.
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
2016 Chevrolet Traverse SUV (A56859)
2016 Chevrolet...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
