Splitting my Zetor 6245...again. Need advice.
/ Splitting my Zetor 6245...again. Need advice. #1
WFOMO
Zetor 6245
I wore the clutch out on my 6245 a couple of years ago and split it for the repair. Put it back together (clutch plate, pilot and throwout bearing), worked fine, but long story short, evidently the transmission seal is leaking and it is now full of oil. I can drive it up against a tree with the clutch out and it doesn't even slow the engine.
So...as I go for my second time around, I'm planning on changing the transmission seal AND crank seal. Is there anything else I need to do while in there to prevent a third try?
/ Splitting my Zetor 6245...again. Need advice. #2
Congrats on splitting the tractor and having it work for you.
Some Eastern European equipment didn't have the best quality seals....yes, that is an understatement & you probably already know that. Just guessing, but how are the master cylinder brake seals???
However, many seals - like bearings - are standard metric dimension. You could look at a Japanese or US seal catalogue to see what else is if offered in that size. I use a Parker Seal & O Ring designer's catalogue when choosing seals. It's a big thick boring book. Also read what McMaster.com has to say.
Not all seal materials have the same resistance to chemicals or the same lip construction. Prices vary a lot. You may want to use a seal technology that would be too expensive for mass production.
There are also some interesting double lip seals available now for direct replacement. You might want to talk to some serious Formula 1 racers or high end hotrodders.
Stick with a known name brand dual purpose Trans/Hydraulic fluid both for seal chemistry compatibility and the additives. I like JD HyTran and NH Ambra Multi G. Others are good; all are expensive.
rScotty
/ Splitting my Zetor 6245...again. Need advice. #3
Did you get it repaired?
/ Splitting my Zetor 6245...again. Need advice. #4
No, it's still nosed up against the tree.
/ Splitting my Zetor 6245...again. Need advice. #5
Sorry to hear this. Make sure your rear vent is not plugged or restricted and make sure the surface of the input shaft where the seal rides not damaged or grooved badly. There may also be a drain in the clutch’s bell housing that may be restricted with debris. Good luck.
/ Splitting my Zetor 6245...again. Need advice. #6
This question is not relevant to your leak, but is helpful while performing the clutch replacement.
Did you use a rail system when you split your tractor?
/ Splitting my Zetor 6245...again. Need advice. #7
Did you fix your Zetor yet? I'm surprised you didn't change the seals when it was split. That's basically a rule of thumb on anything..Tractor, Chevy Truck, etc. Especially when you consider it's 35-40 years old and commie rubber on top of that.
/ Splitting my Zetor 6245...again. Need advice. #8
lol…, almost four months later I realize I was not replying to the OP.
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
Hustler super Z zero turn (A56859)
Hustler super Z...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2019 Ford F-450XL (A60462)
2019 Ford F-450XL...
2021 Dodge Charger Sedan (A59231)
2021 Dodge Charger...
