Mixing MSMA in a 50gal UTV Boom Sprayer on a Kawasaki Mule to spray @ 3mph
   / Mixing MSMA in a 50gal UTV Boom Sprayer on a Kawasaki Mule to spray @ 3mph #1
FMFProperties
Ben Wheeler, Texas
Branson 4520C & Massey 1533
The MSMA label says :
"For established Bermudagrass and Zoysiagrass, mix 1 to 2 fluid ounces (2 to 4 tbsp.) of this
product in 1 to 2.5 gallons of water for application to a total area of 1,000 square feet."
I want to spray a 2.6 acre runway of Coastal Bermuda, but to make the math simple let's stick to 1 acre first.
1 acre = 43,500s' divided by 1000s' = 43.5 (I know it's 43,560s' but I'm keeping it simple, we don't need science class lab results here 🥸 )
So I have to mix 1-2 ounces of MSMA for 1000s', so if I use 1 ounce times 43.5 = 43.5 ounces (1.36 quarts) of MSMA per acre, BUT THEN....
what about where it says to mix it into 1 - 2.5 gallons of water for those 1000s'? If i multiply 1 gallon of water (for 1000s') x 43.5 = 43.5 gallons of water for 1 acre.
My sprayer at 3mph spreads 13 gallons per acre. How many ounces of MSMA do I need for 1 acre spreading 13 gallons of water per acre, OR should I go slower to use more water per acre?
If I go slower, maybe @ 1mph (I haven't tested this speed yet), I might be able to spread at 43 gallons of water per acre, but that doesn't seem logical and the grass would get more water but it would be a more diluted MSMA per acre.
I've called 2 ag stores but they don't seem to know math and give me wild answers, one of them just told me 1.5 to 2 gallons of MSMA for 50 gallons of water !!
HELP !!!!
PS:I know someone will ask so let me get this out now 😊.
I arrived at 13 gallons per acre by actually driving at 3 mph spraying plain water (did 5 passes with a 9' wide spray) over the measured 2.6 acres (46' x 2480'), and it took me 33 gallons of water to do it, so I use a rounded up 13 gallons per acre.
Pictures of the sprayer and first 1000' of the 2500' runway.
   / Mixing MSMA in a 50gal UTV Boom Sprayer on a Kawasaki Mule to spray @ 3mph #2
I used to use 1 quart per acre at 20 gallons of water per acre, have a John Blue pump that compensates for MPH to keep the output at 20 gallons per acre, spraying with a PTO pump and figuring MPH takes a little trial and error, but when I did spray with a PTO pump I had it figured on that particular sprayer that I used that I had to travel at 5.2 MPH to get the 20 gallons output per acre. Once you use a spray rig with a ground driven pump that compensates for MPH you will never go back. Nothing will clean up a hayfield of vaseygrass nutgrass, goosegrass etc better than MSMA but be careful as it is not labeled for anything except turf grass, golf courses, ROW's and for cotton, in other words do what you need to do but don't advertise.
   / Mixing MSMA in a 50gal UTV Boom Sprayer on a Kawasaki Mule to spray @ 3mph #3
You have answered your question. Your sprayer puts out 13 gallons per acre and you need 43 oz. of MSMA per acre. So for every acre, or for every 13 gallons, add 43 oz. of MSMA. With MSMA, the gallons of water per acre is not critical.
I've used MSMA in the past and 43 oz. is a good rate. Not too high, but not too low.
But, as @Lineman North Florida said, please read and follow the label. I don't think that what you are planning to do is on the label. Especially if the grass will be used for hay.
Thank you for the first part.
For the 2nd part, I copy and pasted it directly from the label. Here's my post and here's a picture of the label on my 2.5 gallon jug.
   / Mixing MSMA in a 50gal UTV Boom Sprayer on a Kawasaki Mule to spray @ 3mph #5
The way I read that label, it can ONLY be used on 25% of the total area of a golf course, or on a sod farm. I don't see where it says it can be used on lawns, sports fields, pastures, hay fields, industrial sites, or anywhere else.
I used it on many sites in the past, but the label changed about 10-12 years ago, and now I don't use it at all. I have been a licensed commercial applicator since 1982. I read labels almost every time I spray.
I'm sure you would be fine if you do spray your pasture, but I just want you to be aware of the label and the law.
   / Mixing MSMA in a 50gal UTV Boom Sprayer on a Kawasaki Mule to spray @ 3mph #6
I just went read the label again, and it does have a use on cotton fields, and highway right-of-way.
   / Mixing MSMA in a 50gal UTV Boom Sprayer on a Kawasaki Mule to spray @ 3mph #7
I've used MSMA for several years on my 5 acres of bermuda turf. My sprayer puts out about 20 gal/ac, depending on the nozzles I use. 40-45 ounces of chemical will smoke most weeds in about 10 days or so. Takes a little longer for crabgrass. There are some weeds it won't even touch, so read the label to see if it will work for what weeds you're dealing with.
I agree with previous posters that the amount of water is not critical. Also should point out that it will "stress" your bermuda, but won't kill it. I usually apply some nitrogen/urea a week or two after using MSMA to green things back up.
If your MSMA doesn't have surfactant be sure to add some for best results.
Did 1 quart (32 ounces) per acre work correctly? It came out to 43 ounces per acre in my calculations and I have no problem with using the 43 oz, but if 32 works then I might try that first, better for the wallet. :D
The runway is registered with the feds as a turf grass runway so I'm covered there. Regarding the hay fields, why are you asking about hay fields? :cool::cool:(y)(y)
Thank you. I'm controlling sandburs and bahia, and it's working good. The one I have is already mixed with surfactant.
   / Mixing MSMA in a 50gal UTV Boom Sprayer on a Kawasaki Mule to spray @ 3mph #10
1 quart per acre used to work like a champ for me, always smoked the targeted grasses that I was after.
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
5TH WHEEL PLATE (A58216)
5TH WHEEL PLATE...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2013 International WorkStar 7400 Altec AM547 50ft. Bucket Truck (A56858)
2013 International...
