Fields_mj
- Joined
- Oct 18, 2021
- Messages
- 188
- Location
- Central Indiana
- Tractor
- Ford 1710, Kubota F2880, White FB16
I picked up a 2008 TC40DA in Jan to replace my old Ford 1710. Time will tell, but I'm pretty sure it's going to be some of the best money I've ever spent. That said, I do have one issue with it. After its been running for a while (30min to an hour), it acts like its starving for fuel, or developed an air leak. It looses power, and after several seconds, it dies. It will start right back up, but then does it again within a few minutes. The more I keep going, the more quickly it happens. After 4 trys, it's almost instant. If I walk away for a while (30 min), it will run for another 10 or 15 min before the problem comes back. I first noticed it this spring, but it wasn't as frequent. AFTER the problem started, I had some work done to it at a dealership which included replacing some leaking fuel lines. Problem seems worse after that, but I didn't have a lot of time on it prior so its hard to say.
I thought it acted like a clogged fuel filter, so I swapped that out last week and the problem still exists. I do notice that when the machine is running, the fuel bowl on the filter has about an inch of air at the top, but I can't see the fuel bowl from inside the cab (LOVE having a cab with AC), and by the time I get out of the machine after it dies, the bowl is full of fuel again. I'm normally running the machine in the back yard moving logs or totes of firewood, and I'm normally not running over 1500 rpm, often lower. My thinking is that either I have a lift pump that is weak, or I have air in the line prior to the fuel filter and its eventually getting to the fuel pump and injectors. Problem with that is that I'd think that it would pretty quickly work its way out and back through the return line.
Any thoughts or ideas?
Thanks,
Mark
Thanks,
Mark
