Regret not getting a backhoe for my tractor
   / Regret not getting a backhoe for my tractor #61
Haha, ok sure. You gotta dig a narrow trench on flat ground, thats great. The videos I have seen are them tipping over when on any uneven terrain, and failing to lift heavy things because they simply aren't big enough. If you need a toy digger thats fine, but they simply don't excavate tree stumps or lift boulders effectively. And good luck sourcing obscure parts for your random chinese brand machine 10 years from now. Different strokes, all good.
Edit: just revisited this thread about chinese micro-ex's and its just a giant complaint fest about how terrible they all are. neat.
Watching the wrong videos, OK.
10 years from now they'll be so popular Lowes will be selling them along with the China side x sides. And any part needed
will be on Ebay. Harbor freight has the 14hp engines for $380. So ha-ha......yea. They're fine for the capacity they have.
Don't buy one.
Edit...I looked thru that entire thread. A 'giant complaint fest' ?? LOL Sure. Not.
   / Regret not getting a backhoe for my tractor #62
We considered a BH for the Kubota B2301, but chose against it. For the use I have, it wasn't going to be worth the expense. I have rented a mini-excavator, two days for a bit over 500 bucks, plus 100 to drop it and retrieve it. That's less than 1/10th of what the BH attachment would have cost, and I don't have the room for storage. I'm going to have to rent again next year for something. I'll still be money ahead.
That was my approach as well. Would've loved to have one, but not sure I'd get my money's worth out of it, for the reasons you mentioned. Actually looked at getting a used one maybe 15 years ago...seems all I could find were either 3PH ones (which I didn't want), really beat-up ones that needed a LOT of work or like-new ones with like-new prices.
Not many rental places around me, the one time I needed to dig a ditch hired my neighbor to do it.
   / Regret not getting a backhoe for my tractor #63
A loader is important, and I'm glad my tractor has one with a big bucket. It's proven very useful as I will explain shortly. But the loader just isn't good at digging DEEP holes. This is my first tractor/ranch and, to tell the truth, I was unaware just how critical a deep a hole would be. Don't get me wrong, the loader is great for scooping up the cash, but it just can't dig a big enough hole, in which to put it. In fact I just bought a 15 yard dump trailer. Now I can use the loader to fill it up with cash and then dump it directly into the money pit. A real time saver!
What do you mean by these cutesy phrases?
I couldn't imagine trying to use a backhoe off of a tractor instead of an excavator.
I've wondered if backhoes are like pickup trucks. Most people that own them very seldom use them for its intended purpose.
   / Regret not getting a backhoe for my tractor #64
That's one of the problems with having a backhoe. I get two or three requests a year from friends, relatives & neighbors to do work. Sure, they offer to pay but I find it difficult to take money from them. Maybe I'm just a softie, but I usually do the work for nothing if I can find the time.
   / Regret not getting a backhoe for my tractor #67
Once you do it a few times, it's not really that big of a deal, or take very long, at least on my 2021 Massey Ferguson GC 1725 MB ...
   / Regret not getting a backhoe for my tractor #68
Takes me 10 minutes to install the backhoe, and 5 minutes to remove.
   / Regret not getting a backhoe for my tractor #69
A backhoe is a great thing to have but it all depends on your usage. They are not just for digging.. If you have an hydraulic thumb they are amazing for lifting things into place or removing things!!
It is very important to make sure you get one with a sub-frame if you do decide on one for your tractor.
I have had a full size backhoe since around 2003. Four over the years. Used on our residential propery.. no farm.
73 Ford 4500 $6750
1983 JD 310A $8000
2010 JCB 3CX Turbo 4x4 Extendahoe $36k
And currently here in East Texas
2000 JD 310SE 4x4 Turbodiesel Extendahoe $32,500
Used, sold and bought again. They hold value.
First propery it was all about digging out stumps, grading and moving big rocks.
It was a 1973 Ford 4500 Industrial.
Someone here said you shouldnt use a farm tractor for a backhoe.
This 4500 is a farm tractor that was redesigned by Ford to be a backhoe.
The original pedals are still there under the footboards. The rear end has the same casting that would have had the PTO but no PTO gearing. If you removed the backhoe specific metal... you had a farm tractor.
Here it is with the hoe removed so I could replace all the hydraulic lines to the four stick control valve. Actually six valves when you include the outriggers.
Modern backhoes are purpose built. You can't take them apart like this as a unit.
And here is a view of the rear showing the 3PH attach points and the PTO access. You can see the two large arms hanging from the upper bars and the "hooks" in the bottom ones that the hoe drops into.
That big hyd line above is the feed for the hoe. I had to couple it together. The hoe itself has everything on it just like the detachable small tractor hoes except the seat. It uses the tractor seat and rotates.
And here is the hoe removed..View attachment 3886578
Yep, use my Ford 550 TLB all the time, and even today did a drain rock hole for some run off.
15 foot reach and paid 8k for it versus a small add on for the 55 HP tractor.
Bigger heavier pallets are no problem compared to a regular 40-70 HP utility tractor FEL either, because start around 4500lb lift capacity on a full size TLB and that is extra handy along with increased lift height and also a self leveling bucket.
   / Regret not getting a backhoe for my tractor #70
Heh. When I was in my 20s & 30s living in the southern part of the state ran into the same thing having a truck. You're everybody's friend when they want to move.
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
XCMG CV83PD (A53317)
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
LOT OF PALLET RACKING W/ WIRE MESH SHELVING (A52708)
LOT OF PALLET...
