3510 Front inner tube recommendations or 'No-Flat' fill product?
   / 3510 Front inner tube recommendations or 'No-Flat' fill product? #1
DiskDoctr
Western PA
Mahindra 3510
About 8hrs on new tires and tubes and one tube burst. 28 x 8.50 x 15 R4 industrial tires. Apparently cannot handle the front loader weight.
We wire brushed and cleaned entire wheel to make sure no burrs. So now looking for heavy duty tube and/or no-flat product that will handle the weight.
Also- For decent price/condition, I'd consider buying new front wheels as well.
Tips, products, vendors?
   / 3510 Front inner tube recommendations or 'No-Flat' fill product? #2
My Hy-Run tubes DISSOLVED when I tried to fix a burst seem with 'rubber cement' and a blowout patch.. Try a different brand. Carlisle has worked well for me. Yes, welded wheels intended to be used with tubeless tires often have weld flash that will puncture a tube. I mark the position of the tire and tube when I get thorn punctures so I can I.D. the source.
   / 3510 Front inner tube recommendations or 'No-Flat' fill product? #3
Recently I had to buy some inner tubes for ancient trailer wheels that were all rusted and was amazed that I couldn't find any made here in the USA that would not quickly disintegrate. EVERY one I looked at on line said "Made in China" and most were brands I had never heard of. Finally came across some Firestone tubes that were supposedly made in USA. This is what I found when I pulled one out of the package:
   / 3510 Front inner tube recommendations or 'No-Flat' fill product? #4
Did the tube blow out or did the tire blow out.
As far as stop leaks I have been pleased with the performance of this brand;
I found a pic I took of the tube I took out of it. It had been in the tires for about 10 years or more. One was even patched once and put back in.
I ordered two replacements to be here by the end of the week. My tire guy couldn't get them right now, so Amz* to the rescue!
Amazon.com
   / 3510 Front inner tube recommendations or 'No-Flat' fill product? #6
Wow! If the ones I just installed last at least 10 years I'll be a happy man!
Tube. Tires are new
Carlisle Trac Chief 28/8.50-15 C​
The tubes are supposed to have valves designed for fluid/ballast.
The stuff you linked is preventative to stop punctures, right? How many are needed for the tire tubes?
   / 3510 Front inner tube recommendations or 'No-Flat' fill product? #8
Tube. Tires are new
   / 3510 Front inner tube recommendations or 'No-Flat' fill product? #10
Translation: "How much of the stuff do you put in a tube?"
So 28x8.50-15 would be 28 x 8.50 = 238 / 4 = 59.5 or about 60 oz.
UNUSED IRGC40 Battery Powered Mini Golf Cart (A55272)
UNUSED IRGC40...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
500BBL WHEELED...
2008 Mazda CX9 SUV (A56859)
2008 Mazda CX9 SUV...
3015 (A56857)
3015 (A56857)
1991 Eager Beaver 24ft. T/A Dovetail Equipment Trailer (A56858)
1991 Eager Beaver...
