Rotary Cutter Woods BB720X
/ Woods BB720X #1
medic106
Essex Jct, Vermont
Kubota
Just bought my new tractor Kubota mx5800, I am just wondering what my brush hog can handle I have some fairly thick sapplings. Any suggestions or advice is appreciated.
/ Woods BB720X #2
They are rated for up to 3" but you will know if you cut anything that thick - it will make a heck of a racket!
Product Details
WOODS BB720X
Cutting width 72"
Transport width 79.5"
Overall length 116"
Cutting height 2" - 12"
Approximate weight 1,200 lbs
PTO Horsepower 30–120 hp
Tractor PTO speed 540 rpm
Hitch Cat 1 & 2 / Clevis
Quick hitch compatible yes
Driveline Cat 4
Driveline protection slip clutch
Gearbox output shaft diameter 2"
Gearbox HP 120
Blades (2) .5" x 4"
Blade composition heat treated alloy steel
Cutting capacity 3"
Blade carrier round stump jumper
Blade mount system quick-change blade pins
Blade tip speed 15,900 fpm
Blade pin diameter 1.5"
Frame & deck support 3" x 4" full length structural beams
Skid-shoes heavy-duty replaceable
Rear bumper 2" tubular
Cutter deck thickness 10 gauge
Deck side depth 12.6"
Side frame thickness .25"
Tail wheel 4" x 16", laminated
/ Woods BB720X #3
I've got my BB720X mounted on one frame size up and the cutter itself is very robust.
I expect you'll enjoy a lifetime of use mounted on your tractor. :)
/ Woods BB720X #4
BTW, the best time to brush out junk is when you can see what you're doing.
/ Woods BB720X #5
I've never heard "picking up twigs" connected with brush hogging. Anything smaller than my wrist I run over and chop into mulch. I agree the best time of year to mow off ground cover is when it's leafless.
/ Woods BB720X #6
"Twigs" was used as a slang term when I was picked up large chunks of windfall birch trees.
/ Woods BB720X #7
View attachment 484770View attachment 484771
I have that same mower on an L5740, and it has been really good. Just last year I had to replace the input shaft seal, but that's the first and only repair in the nearly 20 years that I have owned it. And I work it hard, with frequent encounters with hidden stumps and rocks.
When cutting saplings, the underside of the tractor is more vulnerable than the mower. I have broken a variety of things over the years on my tractor because of saplings, sticks, and branches getting shoved into places where they are not welcome.
/ Woods BB720X #8
Yep! One year I ran a 1"D stick through my oil filter. Since the oil filter is above the exhaust pipe on a MF135, a punctured oil filter became obvious before I noticed the oil pressure dropping.
2012 Addco DH250-FM Towable Solar Message Board (A64553)
2012 Addco...
2007 FREIGHTLINER COLUMBIA TANDEM AXLE 6 X 4 TRUCK TRACTOR (A67147)
2007 FREIGHTLINER...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
1993 Brenner 307 SS Insulated T/A Chemical Tanker Trailer (A64194)
1993 Brenner 307...
