Good morning!!!!
   / Good morning!!!! #209,851
71°F and .03 inches rain.
Interest, but not in best way day yesterday
Managed to dislodge rear tire off rim, broke bead both sides.
A 15 minute job for sime of you guys, not me.
My first task this morning
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #209,852
Prayers for all
Be safe
Have a great day
Sorry, hate when that happens. I only had a front tire do that, would hate for a back tire to come off.
   / Good morning!!!! #209,853
Success
Shot of ether/starter fluid and BOOM.
Seems to be holding at 23 psi.
Of course started raining just as I finished.
   / Good morning!!!! #209,855
67F nice much needed steady rain for the next couple hours.
Steady morning getting somethings done...whew,afternoon 2 dump runs thank goodness I had 16' chain in toolbox pull hot water tank off. :) able to sneak short nap in.
Plans for the evening :unsure:.
Enjoy your evening all.
   / Good morning!!!! #209,856
What brand did you go with?
I have to wonder how much longer mine has it's an Amtrol that got put in over 30 years ago.
Not sure about your state but in our state mixing valve required set to least 140 so legionnaires disease doesn't grow.
   / Good morning!!!! #209,857
I'm not aware of any "requirements", my Amtrol is set about 120F.
I don't use a mixing or tempering valve. A circulator off the boiler set to turn on when the water heater is cooler then set point and off just above setpoint.
Edited:
OK, I see that you have a new electric water heater. When I read stone lined I just assumed it was an indirect water heater, my bad.
   / Good morning!!!! #209,858
Good evening! Tried to go for a walk but still too hot 40 minutes before sunset. 91F with a heat index of 100˚. I did get a little done today got the truck inspected and registered. Emissions inspection was $11.50 and the registration was $78.00 so good for another year. There are only 17 counties in Texas that require an Emissions inspection. The ones that are near heavy populated areas. Our county includes some of Austin.
Got the "call back" email from the "Farm" today, they are requiring working on weekends in October for the Fall festival. I signed up for the required orientation next month, going to give it one more season before I retire for good.
   / Good morning!!!! #209,860
New blades installed and torked to 100 ft/lbs. Book calls for 100-120ft/lbs. Almost all the grass cut. The septic mound will wait until the next cutting. Am cutting at 4".
The hornets nest quiet today. I guess the liberal dosing they got yesterday killed them all.
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
GooseNeck Trailer (A52377)
GooseNeck Trailer...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A55787)
2007 Godwin Pumps...
FRAME ONLY FRONT DISCHARGE CONCRETE TRUCK (A54313)
FRAME ONLY FRONT...
30008 (A55758)
30008 (A55758)
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
