LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,271
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Many older houses and barns are set close to the road and many are separated by the road was the original path went between them as a cart track. Most people back then would not have a useless yard it would be grazed.Good (Saturday) morning. Overnight Low of 4.3C and it's presently 12.6C, mostly cloudy & fairly calm.
It took me quite a while to figure out why so many, post 1920's, rural homes/farm structures were built so close to the main road/highway.
The answer is power poles. If your building was farther away from the power 'line' that it required your own pole(s) to reach you, then you were responsible for the cost and maintenance of 'your' pole(s).
My house is set back from the road (built 1993) as the power line is buried. If I needed power poles, I would still be required to be responsible for them.
Once again, that's about it, take care all.
As time went on and money and time became available to waste the front yards came into being. Many of the old paths were modified as the "new" roads came into existence as often there would not be enough room to follow the old paths.
