   / Share Pics of People Hauling or Towing Something Wrong #22,831
It's a Jeep! They're accustomed to riding on a car hauler. :)
But I wonder if U-Haul knows their trailer was backed down the ramp into the water to launch the boat. Some later customer will likely discover trashed wheel bearings. Or taillights.
   / Share Pics of People Hauling or Towing Something Wrong #22,832
Probably fine. Most well-greased bearings won't even notice a single dunking at the ramp, it's the cumulative effect of many dunkings without frequent-enough re-greasing, that ultimately does them in. Most tail lights made the last 40 years are of the "diving bell" design, a vent/drip hole at the bottom, but sealed with a foam or better gasket around the rest of the perimeter. They can take in a little water if left dunked long enough, but usually not, unless the gasket has totally rotten away.
Wiring negative polarity connections, such as the common splice between the main harness and each tail light or tail light to chassis ground, are the usual failure points when water-tight splices aren't used. But the U-haul maintenance guys have probably been there / seen all that before, so I suspect they use decent splices to avoid the cost of frequent re-work.
The plywood sides on their ubiquitous enclosed trailers won't hold up well to frequent use in fresh water, but even those probably won't suffer much damage from an occasional or one-time dunking.
As someone who owns antique wood boats hauled on vintage steel trailers, I know well the old saying that the tin worm lives in salt water, but wood worm lives in fresh water. With wood boats on steel trailers, I'm hosed in any type of water. :D
   / Share Pics of People Hauling or Towing Something Wrong #22,833
don't be this guy
i mean don't be the guy in the car in front, either, but still
   / Share Pics of People Hauling or Towing Something Wrong #22,834
In my house there commonly referred as cripesler products lol
   / Share Pics of People Hauling or Towing Something Wrong #22,837
Is this even legal?
   / Share Pics of People Hauling or Towing Something Wrong #22,838
Is this even legal?
I don't know if it is or not by the letter of the law but I see a lot of those combinations heading west on I-30 and south on US 59. It looks sketchy to me but maybe I am just being sensitive about things like that.
   / Share Pics of People Hauling or Towing Something Wrong #22,839
Headed south to the border. Coming from auction, going into Mexico.
   / Share Pics of People Hauling or Towing Something Wrong #22,840
I thought that the first towed vehicle had to be a gooseneck/fifth wheel and the second a BP to pull double trailers?
(4) FORD 255/65-17 TIRES W/ 6 LUG RIMS (A58374)
(4) FORD 255/65-17...
M998 (A55852)
M998 (A55852)
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
JOHN DEERE 68 FEED CART (A52708)
JOHN DEERE 68 FEED...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
