I finally bought a Deere 6120M
   / I finally bought a Deere 6120M #1
hayden
Elite Member
VT
Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
After lots and lots of searching, back and forth between Deere 5 and 6 series tractors, looking closely at Fendt and other brands, I finally bought a 2024 6120M IVT with 620R loader.
The exacting ground speed control of the HST in my Kubota L5740 has been key on my property because there is a lot of steep and uneven ground where you need to carefully maneuver. An HST is also priceless for loader work. The problem is that the largest HSTs available top out around 60-70hp. My current tractor is 60hp, and is under powered for the snow blowing I do, and under sized for mowing with a batwing.
Kubota's M5, M6, and M7 tractors are very basic economy models, all with teh most basic transmissions compared to other brands. Their compacts and small utility tractors are great, but in the bigger stuff other brands seem a lot better.
Deere's 5 series tractors are about the right size and HP range (100-120hp is what I'm after), but they only are available in a partial power shift. In particular, the range shifting is manual, and gear shifting is power shift (shift on the fly with the press of a button). And the control layout in the 5M series I find unusable with the shift lever positioned so it's essentially under my thigh.
Then I started looking at the 5R that was only built for a few years, but was available with a full power shift for ranges and gears. I flew around the country looking at them, and even attempted to buy two of them. But thankfully those deals didn't come through.
Then I decided to look at the 6 series where you can get an IVT transmission. The 6 series is really a lot bigger than I need, but the 6090, 6110, and 6120 are a shorter wheelbase than the other models, so not THAT much bigger than a 5 series. So off I went to look at them, but I just found them overwhelmingly large.
Then someone suggested I look at Fendt because they are all IVT transmissions, and they have a model (211) that is about the same size as a Deere 5 series. So I talked to dealers and to Fendt directly, was frustrated getting the most basic info, found their web site to be terrible and seriously lacking on info, especially compared to Deere. Also, their list prices are VERY high ($200k+ new), the closest dealer is 6 hrs away, and they don't seem to have sold more than a couple of this model in the US. But they are supposed to be the greatest tractors on the planet, so I kept looking. Then I got a formal quote, and it was significantly discounted, which really put it back in the running. Then I had a chance to go see two similar models in person, so off I went on another road trip. Honestly, they strike me as overly complicated, and I wasn't seeing the best online reviews and experiences.
Then I discovered the real gotcha. Deere (and lots of others) have independent hydraulic control valves for the rear remotes and for the loader. My mid size Kubota has that too, and I presumed it was standard practice for anything other than a budget tractor. Nope, not so. Fendt actually robs two of the rear remotes to operate the loader. So if you have a total of three rear remotes and you install a loader, you now only have one rear remote. WTF? OK, I could add a fourth rear to now have two usable, but again, WTF? I have three usable on my lowly Kubota, but the cat's-ass Fendt tractor to beat all tractors can't have more than two when you have a loader? Did I say WTF?
But wait, it gets better. Any mid to high end tractor can have a third hydraulic function on the loader, and some even a fourth. Fendt offers a 3rd, but it's not a dedicated valve, but rather a diverter valve that repurposes one of the circuits that's already been stolen from the rear. So you can't simultaniously lift, curl, and grab with a grapple. With Deere I can have as many as 4-5 rear remotes depending on the model, and 4 front remotes, all at the same time. So I told Fendt and the dealer that I was really taken aback by this, and that the tractor would really be a step backwards for me in all ways except HP, not a step forwards, and that consideration of the them was "on hold".
Then someone on a Deere forum pointed out that the 38" rears commonly used on the 6M make it seem really big, and that with 34" rears it might not be so overwhelming. So off I went down that path. I found a dealer that had both a 6110M and a 5R on the lot, so off I went with a tape measure and calculator to see just how much bigger the 6M would be if you put 34" tires on it. Keep in mind that not all 38" or 34" tires are the same outside diameter, so you need to compare specific tire sizes. But the bottom line was that with the same size tires, the 6M only stands about 2" higher than a 5R (or 5M), and is only 2" longer. So now the 6M was back on the table.
A week or two ago I plowed through all the ads and picked out all the 6120Ms with IVTs, compared all the features, and figured out which was my first pick, second pick, etc. I was also only considering tractors with the electric rear and mid remotes, which also means a CommandArm control console. Many 6120Ms don't have loaders, so the comparison included adding a loader where needed. It turned out there was one with 34" tires (it's very expensive to change from 38" to 34" because you have to change tires, wheels, and discs, so roughly $20k). They are a bit larger 34", and if I wanted to change them it would only be changing the rubber. And the tractor was otherwise a good match. I had other business not too far from the dealer, so I set off on a combined trip this week.
The tractor was used only one season on a lease by the state for road side mowing, only has 300 hrs, and a year left on the warranty. They offered a good deal on an in-stock new loader, and agreed to fix a couple of minor things and truck it to my house. So I bought it. I expect it will take a couple of weeks to get the work done and get it trucked, and then I'll need to do a handful of other things, first of which is to add a bunch of ballast. The loader specs call for a lot of ballast both on the wheels and the 3ph, so I have to figure that out. And a handful of other smaller things.
So finally, the search is over, and my yard is a bit greener than it was before.
   / I finally bought a Deere 6120M #2
That's a really nice tractor.
What will you use it for?
And what was your final cost?
   / I finally bought a Deere 6120M #3
Nice, very nice, congratulations.
Way back in the 70's, I was reading all about the new 6000 series with a cab in the Deere magazine Furrow.
I lived on a small lot in town and I had no use for one, but I still really wanted one. I still want one and still have no use for one other than driving it in parades.
   / I finally bought a Deere 6120M #4
hayden,
Does Deere separate their transmission fluid reservoir from their hydraulic fluid reservoir?
BTW, congrats. Thats a really cute tractor. We know you went through painful detail and a lot of questions to make your decision.
On the Fendt, you can as you said, add a remote and with a simple splitter, make it into 2 remotes. If that's your big deal breaker gripe, I say “WTF”????
I have 4 sets of remotes on my 7495 and wanted a 5th set, so I spent $600 on a splitter.
IMO, I be more worried about dealer support on Fendt since you say your nearest dealer is 6 hours away. Wonder if it’s my dealer? Which is 45 minutes away lol
hayden,
It's a single reservoir, so I'll keep on top of oil and filter changes.
I was really surprised about the Fendt SCVs, as you can tell. But it was really a collection of things. Distance to dealer (western NY), struggle to get technical info despite a great effort from the dealer, limited technical documentation, closed system from a diagnostic and repair perspective, very tiny foot print of customers, control systems that seems overly complicated yet not really able to do much that Deere couldn't do, and limited options and accessories
I have to say that I've been very impressed by Deere. Tons of info available, all sorts of options and accessories with tons of info available on them too, easy parts ordering from dealers or online, parts filtered to the machine serial number, good resale, lots of Dealers everywhere, and this vintage of 6 series machines seem to be really reliable.
But check back in a year and see if I still feel the same way....
Mowing, snow removal, and loader work. No haying or row cropping, which I think are the more common uses. It's overkill, but I wanted the IVT. The same HP (or a bit less because the tractor is lighter) in a 5 series would have been fine in terms of size.
   / I finally bought a Deere 6120M #7
Single reservoir??? WTF???? 😁
Just messin with you.
I don’t like single reservoirs for CVT/IVT and hydraulic fluid together.
1. A hydraulic leak could drain your CVT/IVT dry, which is a disaster you might not know about until it’s too late.
2. Hydraulic fittings (that you need so many of on back of your tractor 😁 )will introduce dirt into the CVT (IVT) with every connection of a hose.
IMO, for a $180,000 small chore tractor with a CVT/IVT, cheaping-out with a single reservoir is a deal breaker for me. I want them separate. The reason I know all this is because a fellow farmer buddy of mine down here has a Deere 7 with an IVT and he likes my CVT’s better, but that’s a whole ‘nother discussion.
I think you were hyper focused on a minor, curable issue. I don’t care what you buy, but that wouldn’t have been a deal breaker for me. I would have installed splitter(s) as I did on my Massey. I can’t imagine how seldom I’d want to raise my loader at the exact same time I’d want to raise my mower. :unsure:
Those are definitely legit reasons. A lack of dealer support to that extreme you have would be a deal breaker for me, too.
But that Deere single reservoir would really bother me, especially when the going gets rough, even with a dealer nearby. I’ve lost hydraulic lines a number of times, not knowing, and my hydraulic system was almost empty.
What chu talkin bout Willis? 🤣 We have hundreds of them running around down here….lol
Fendt makes the ultimate push-button/comfort tractor. They have amazing drivetrains and braking systems. Man diesel engines are the schitt.
Deere, Massey are a very close second.
Yeah Deere has lots of dealers. That’s for sure. I’d say you made the right decision for YOU, but I still say Fendt’s still the best IF you have a dealer within reasonable distance, which you don’t have.
Let me know how good the Deere IVT is at “feathering” when doing loader work. I found it to be too jumpy for me. And of course whatever you like/dislike. I’m interested in all brands.
Most of all enjoy it!
Yup, you got me on the dual reservoir and the WTF? :). I honestly never even thought about it.
As for Fendt "footprint", I'm primarily talking about 200s. The only one Fendt and the dealer (who I thought did a really good job helping me out) could point me to was in the Pittsburg area. None out in Washington either where I spend a bunch of time. That's where I was able to see a 300 series, and a couple of the 200 mini fruit tractors. They clearly have a strong presence where you are, and if that were the case here, I'd probably feel differently. The 200 series also use the Sisu 3 cylinder engine which is much rougher running than the Deere (and probably other) 4 cylinder.
Anyway, much is personal choice, and I'll be the first to acknowledge that controls that "make sense" and are "intuitive" to one person are non-sense and confusing to others. My brain took to the Deere controls much more than the Fendt controls.
As for cost, all in with the loader and trucking it's about $150k for a 1 year old, 300hr tractor. A new 5M configured as close as possible, but still without an IVT and with a lighter loader is $140k. And the same 6M new is $240k. It's way more than I ever thought I'd spend on a tractor, but I'm happy with the deal. I got all the service records from pre-delivery through to lease return, and the only issue was a leaking hydraulic fitting where the o-ring was replaced. I also checked all the stored codes in all the controllers to make sure there wasn't anything going on. The only issue, which I had found on inspection, was the control cable knocked off one of the unused mid SCVs, probably from debris while mowing. The dealer is going to fix that, and I'll verify it before closing.
   / I finally bought a Deere 6120M #10
How many acres are you mowing? With my 70hp Massey and 12 foot batwing, I'm mowing about 30 acres with $68,000 worth of lawn mower. It makes no sense, but it works and I'm happy with what I have.
LOT: Misc. Oils, Coolants, Tires (MOST OPENED OR PARTIALLY USED) (A59076)
LOT: Misc. Oils...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
