Can you mix Ag' and R4's
   / Can you mix Ag' and R4's #1
thclimer
Eastern NY
New Holland TC33D, Massey 1736
I apologize if this has been asked before.
I have a friend with a Kubota L235 (about 40-years old) one of his front tires developed a sever sidewall leak. He currently has Ag tires on the rear and front (6-14, 4PR) and was wondering if he could replace both fronts with a R4 style tire while keeping rear tires as Ag’s. His tractor is 4-wheel drive.
If he can use R4's on the front what would the tire size be?
   / Can you mix Ag' and R4's #2
   / Can you mix Ag' and R4's #3
The important measurement is the circumference of the tires, the same ratio between front and rear must be maintained to avoid expensive problems. Printed tires sizes are rim diameter only.
IMO it's time to grab a tape measure and do your homework.
He decided to replace both front's with R1's and tubes as it originally had.
   / Can you mix Ag' and R4's #5
Probably a wise decision.
For a Kubota L235 4-wheel drive tractor, the standard front tire size is 4.00-15, and the standard rear tire size is 9.5-24. The 4WD system utilizes a front axle that is significantly different from the 2WD version, according to a Kubota parts website.
Detailed Tire Information:
  • Front Tires: The standard front tires are sized as 4.00-15.
  • Rear Tires: The standard rear tires are 9.5-24.
  • 4WD System: The L235 4WD has a unique front axle design that allows for better traction and maneuverability in challenging conditions. When in 4WD, the front and rear wheels work together, and a differential lock can be engaged to provide even more traction when needed according to a YouTube video on Kubota tractors.
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
White Metal Roof Panels (A55758)
White Metal Roof...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
