Harbor Freight Predator 8750 Watt Open-Frame Inverter Generator Troubleshooting ideas
   / Harbor Freight Predator 8750 Watt Open-Frame Inverter Generator Troubleshooting ideas #11
You should adjust your valves. Had a similar issue with a champion and sportsman unit. the sportsman one actualy showed up as knocking and blowing blue smoke.
All good suggestions and will definitely be checked but how would that affect the tightness of the engine IF the spark plug was removed. There would be no compression and only valve spring pressure and overall friction of pistons and bearing journals.
   / Harbor Freight Predator 8750 Watt Open-Frame Inverter Generator Troubleshooting ideas #13
Isn't it under warranty?? Take it back to HF and complaint loudly.
Good advice. I had an almost New predator engine that I could not pull the crank rope. Just seized up setting for maybe two weeks. I chunked it.
   / Harbor Freight Predator 8750 Watt Open-Frame Inverter Generator Troubleshooting ideas #14
Im surprised it lasted that long. I repair generators for a living, and you would not believe the number of these chepo Chinese generators i see. There also the only small portable units ive encountered that tend to blast houses with uneven power out of outlets. Like 200 volts on one phase and 40 on the other. Nearly every service call ive had involving this kind of damage was due to a predator generatorr.
Mine you , Generac has its issues with high power also. Older 2004-2008 era stabdbys will produce something like 370 volts when the voltage regulator fails. Newer units (2008+) will auto shut down if this happens. The older ones just keep running frying everything in their path. But at least each phase is balanced
I dont know how predators get the uneven phase issues, but ive seen it multiple times over the years.
   / Harbor Freight Predator 8750 Watt Open-Frame Inverter Generator Troubleshooting ideas #15
Gas thank you for that information. I don’t necessarily want any unpredictable voltage on my high priced Chinese appliances. Very useful information
   / Harbor Freight Predator 8750 Watt Open-Frame Inverter Generator Troubleshooting ideas #16
I have a small Chicom log splitter. After a few months, sitting for a while, I went to start it. Felt locked up. Little by little I got it to turn... eventually got it started and I think I saw liquid spit out. Sits under an overhang.
Been fine since. Almost thought the engine was toast. Maybe fuel seeped in? Oil from the head? Who knows.
   / Harbor Freight Predator 8750 Watt Open-Frame Inverter Generator Troubleshooting ideas #17
My Predator 2000 and 5000 are/were fantastic machines. I still have the 2000 and it's been extremely reliable for many hours and easy to start.
I had a brand new engine (Kohler on a mower) have a problem not too long ago and it was because the needle stuck open and filled the entire engine with gasoline. It could not turn and everything had to be drained and flushed. The company then installed an in-line fuel shutoff valve. If it won't turn over, maybe this could be it.
   / Harbor Freight Predator 8750 Watt Open-Frame Inverter Generator Troubleshooting ideas #18
Seems to be a common problem with the chinese engines.
I've taken to shutting them down by just turning the fuel off, and leaving the ignition on to drain the carb of fuel, and prevent a crankcase full of gasoline
   / Harbor Freight Predator 8750 Watt Open-Frame Inverter Generator Troubleshooting ideas #19
Try putting oil in through the spark plug hole, fogging oil if you have it. Then start with the spark plug out and try pulling it over and see if it gets any better.
   / Harbor Freight Predator 8750 Watt Open-Frame Inverter Generator Troubleshooting ideas #20
Harbor Freight! Take those two words and work backwards from there!
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
More info coming soon! (A56859)
More info coming...
2018 Grove TMS 700E 60 Ton Hydraulic Truck Crane (A60460)
2018 Grove TMS...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
