Buying a ZTR, what should I look for, or avoid?
   / Buying a ZTR, what should I look for, or avoid? #141
I just picked up a new Husqvarna z-454 for my parent’s 4 acre lawn. It’s got a Kawasaki 23 hp engine. I’ve cut it with it three times so far and it’s worked well, knocking it out in about 2 hours and averaging about 2.5 gallons of gas per cut.
It does not have the suspension seat on it but that is an available option that the dealer said lists for $800, but he could get me for $400. The stock seat is pretty comfortable.
View attachment 3510572View attachment 3510573
The only thing I don’t like about it is the rollbar. I folded it down to fit under some branches over there, but it still hooked one on my last cut and pulled it down against my ear. No blood, but that hurt fur a while.
There are no slopes or ditches on their yard, so I’m going to take the damn thing off and see if I can bolt it onto my Farmall Cub tractor. It would be nice to mount a canopy to on that.
This is a commercial mower. It’s quite a bit smoother than the 5 year old residential version (model MZ-454) that my dad had previously. That one had a Kohler engine on it which has now gone out of business.
Hate to be the bearer of bad news, but Kohler engines are still being made in Hattiesburg, Mississippi. They have been there for years. They are also being made in China.
   / Buying a ZTR, what should I look for, or avoid? #142
You sure those are not Rhelkos ? Check your spelling, may have mixed up some letters.
   / Buying a ZTR, what should I look for, or avoid? #143
Kohler manufactures internal combustion engines at several locations worldwide
Their primary facilities include:
  • Hattiesburg, Mississippi, USA: This plant specializes in gasoline engines, particularly the low-mix, high-volume models like the Courage series.
  • China (Kohler-YinXiang Ltd.): A joint venture established in Chongqing manufactures small gasoline engines.
  • Italy (through a subsidiary, Lombardini Srl): This facility specializes in the production of diesel engines, according to Rehlko Engines.
While Kohler's headquarters remain in Kohler, Wisconsin, engine manufacturing has been consolidated in Hattiesburg, Mississippi. They also have a global network of sales, service, and distribution centers. ”
Koehler makes and sells a Diesel engines bearing the name Rehlko.
   / Buying a ZTR, what should I look for, or avoid? #144
I’ve been researching ZTRs too, so I'm glad that I've found this topic. Thanks for sharing your experiences!
What about Grasshopper mowers? I didn't find any posts about them here. Are they good? I checked Grasshopper Mower reviews, and lots of users praise their longevity and ease of maintenance, but note that parts can be pricey and service is often dealer‑only.
   / Buying a ZTR, what should I look for, or avoid? #145
I’m pretty sure the new name with the mixed up letters applies to the gas motors now too, so that the could concentrate on plumbing supplies with the “Kohler” name.
   / Buying a ZTR, what should I look for, or avoid? #146
You are correct.
“Kohler Energy, which included Kohler Power Systems and Kohler Engines, was rebranded as Rehlko in September 2024.
The rebranding of Kohler Energy to Rehlko follows the acquisition of the former by Platinum Equity in May 2024, establishing it as a separate business entity focused on energy solutions, according to Power Progress. This change means that the engines and power systems previously branded as Kohler are now part of the Rehlko brand.
It is important to note that the name Rehlko is derived from the letters of Kohler, reflecting the company's heritage while signifying a new focus on energy solutions, says Rehlko's chief brand and sustainability officer, Francis Perrin, according to OEM Off-Highway and PR Newswire.“
   / Buying a ZTR, what should I look for, or avoid? #147
I’m You are correct.
That’s about what our local Husqvarna dealer told me.
I’ve had decent luck with older Kohler engines in my Wheel Horse and John Deere Lawn tractors, but not so much with the newer one in my dad’s Husqvarna MZ-454, “residential series” zero turn.
Our dealer thought we’d be significantly better served by the Kawasaki engine in the new Z-454 “commercial” series zero turn.
   / Buying a ZTR, what should I look for, or avoid? #148
Your dealer would be correct
   / Buying a ZTR, what should I look for, or avoid? #149
You are correct.
It will be interesting to see if there is an improvement with their stationary engines that would also harken to Kohlers heritage when they made decent ones.
I am not holding too much hope as this consortium seems to have screwed up their Oregon Tool acquisition.
Equity enterprise is only interested in one thing:
Capitol acquisition and many times that involves cuts rather than reputation of quality.
2021 CATERPILLAR D3 CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2008 Kenworth T800 Semi Tractor, VIN: 1NKDX4TX68R235070, Day Cab, Cummins ISX-600 Turbo Diesel (A59076)
2008 Kenworth T800...
2025 TPM-16 Mini Hydraulic Excavator W/Dozer Blade (New/Unused) (A59225)
2025 TPM-16 Mini...
2010 FORD F-150 (A58214)
2010 FORD F-150...
26in Digging Tooth Bucket Excavator Attachment (A55973)
26in Digging Tooth...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
