   / Share Pics of People Hauling or Towing Something Wrong #22,702
Not really hauling badly, but why would you try to take a trailer through a drive through.
Guy cleared by about 4", and then the tires and fender missed the side of the building by about a 1/2".
I’ve done it back when everything was drive through only for Covid. Maybe he couldn’t park the trailer. Fast food places aren’t known for having big parking lots.
   / Share Pics of People Hauling or Towing Something Wrong #22,703
He had plenty of room off to his right to park.
   / Share Pics of People Hauling or Towing Something Wrong #22,704
This is why I don't like straps for tieing my wheeler and snowsled into the truck. This is the second time... first time I don't know how the sled stayed on.View attachment 3760480
View attachment 3760481 This old piece of rope is the only reason I didn't lose it.
I learned a long time ago to try and find a place like an a arm to strap without compressing the suspension , add the low pressure tires I will lose a srap. Definitely not recommended but I use the winch hook on a weld on dring like a failsafe. See quite a few folks hauling snowmobiles with out running a strap in the back. Luckily I always do took one trip to the ditch long ago with a two place snapped both aluminum tie down bars over the snow machines skis only thing that kept the snowmobiles on the trailer were the rear straps.
   / Share Pics of People Hauling or Towing Something Wrong #22,705
Anything with a suspension that can move and allow some slack is likely to come unhooked. Even just a tire flexing can be enough to relax a binder. Any hook that is not latched on a load that can move is asking for trouble.
   / Share Pics of People Hauling or Towing Something Wrong #22,706
Well color me curious... if you don't use straps, what do you use? Chains? Ropes? Faith?
   / Share Pics of People Hauling or Towing Something Wrong #22,708
There are hooks with carabiner style spring loaded closed ends which will not unhook during momentary slack in the tie strap. I wish I could find some for reasonable prices. Or a carabiner honestly rated 2000 pounds or more.
I don't have a picture but many dirtbike friends use a rubber hose which fits over their hook end and the other end is loosely threaded through the strap end of the hook. Appears you have a double wire hook for which a hose might not fit over as well as the single wire hooks.
   / Share Pics of People Hauling or Towing Something Wrong #22,709
Like these 2k and 6k straps with locking hooks?
   / Share Pics of People Hauling or Towing Something Wrong #22,710
Places that sell tree climbing gear will have biners rated at 5000 or so. Like this:
My local Vermeer dealer also sells climbing gear.
202482 (A54757)
202482 (A54757)
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2008 Ford F-450 Crew Cab Utility Flatbed Truck (A55973)
2008 Ford F-450...
3650 (A47477)
3650 (A47477)
