Good morning!!!!
   / Good morning!!!! #208,761
Good Morning
63° and 99% RH this morning. High in the middle 80’s with slight chance of rain under partly cloudy skies.
Yesterday went pretty well. I cleaned up in the shop while I waited for the TSA, they arrived right on time. And to my surprise, were very nice. The inspection went well, perfectly might be a better adjective. No issues and not time consuming. Afterwards they wanted to go down and see the alpacas.
Next on the list was the mini split in the shed. Fortunately, the issue was installer error. I pressurized it with 400psi of Nitrogen, and the error was easily found. I heard it with the good old Accutrak ultrasonic leak detector and then verified it with good old bubbles.
As you can see the issue was some sort of inclusion in the copper right at the flare. This was a connection that I did, but I did use the cheap copper line set that came with the unit, but I cut it to size and re-flared it.
After fixing it, I pressurized it with N2 again and let it sit for a couple of hours while I went to take advantage of Whopper Wednesday at the new local Burger King. When I came back, the pressure was 10psi higher than I left it, due to the hot sun baking the condenser. I considered that a pass, there were no more bubbles, and the Accutrak was quiet.
Next step was to pull a vacuum, so while I was waiting for that, went down to son’s and looked at the 15 year old LG mini split in the old smoke house, now my DIL’s photography studio. That one was an easy fix, rodents had chewed through a wire in the outdoor unit.
By the time I got back up to the shed, the vacuum was down to 450 microns, so it was ready to charge. I weighed in 24 ounces of R454b (which is practically unobtainable now) and the unit is humming along making cold air again.
Next chore was the batteries for the UPS’. I bought three 12v 9ah SLA batteries for just over $60 with tax at warehouse battery. They are only a 20 minute drive for me and always have given me great service, and they stand by their batteries as well.
Last thing was an Airport Authority meeting, there was an executive session to deal with some potential legal actions prior to the normal meeting, but other than that it was just normal business.
Today will start with breakfast with the professor, then the rest of the day is up for grabs.
   / Good morning!!!! #208,762
Good morning TBN!!
66 this morning. Cloudy going to 90 and more rain forecast. 1.5" last night. We need it. It's been raining all around us for the last week or so but none here.
Thankyou for the Bday wishes!!
Spent a good part of the day picking and moving big rocks to the bridge. One side is pretty much done. One more spot to shore up. Then will order up some concrete.
No real plan for the day. May get my haircut and check out HF. 20% coupon for ITC members. I'm sure there must be something I can't live without :)
Time for a second cup.
Everyone have a great and safe day!!
   / Good morning!!!! #208,763
Some of the better tractor radios have the weather band in them and would break in over the FM if an alert was issued.
And I have seen other AM/FM radios with Weather Band alerts.
Most local FM stations will start broadcasting weather alerts as well.
   / Good morning!!!! #208,764
good morning, 71 going to 83 with more rain possible
Mower got stuck hanging up on a tree on a steep slope. Traction backing up is very poor. Manipulated it sliding the wheels until it finally turned the back end downhill and got out of there. Good traction going uphill as long as the ground is not wet.
The suitcase cast iron weights on the back of the ZT helps traction going uphill a lot but backing up not so much
The farm diesel tank went empty and was filled up. Have not seen the bill yet
Mini split was cleaned. The inside unit was actually not that bad and the drum blower did not have to come out, The evap spray works well to clean the evaporator. The condenser unit outside was cleaned as well and had a lot of pollen on it. Charge was checked and found OK. Bill to follow
   / Good morning!!!! #208,765
Morning all, 68 going to 83 and cloudy, had some rain and lots of thunder last night.
Worked on the chainsaw yesterday putting on the new exhaust, it actually made a difference for the little CS490.
Still need to straighten out the one board for my friends table, it's not moving even with plenty of humidity.
Happy, happy birthday!
Back to the day job.
Be well,
Cleaned screen, added new exhaust and took it noodling in a 30" ash round. Did not bog down like usual. Shindaiwa exhaust exact match up thanks to xyz123 advice. and yes, I run a 20" bar on this little saw just fine.
   / Good morning!!!! #208,766
Mostly,
I don't recall how old the sirens are. They started out as CD Sirens, so that should help date them. We still have two in use. Had 8 total at one time. Home alarms
were bought in the late 60s early 70s to go in members houses. We started acquiring pagers in late 90s early 2000s for each member. But the fire sirens were still primary notification. Now you can get alerts on your cell phone.
The original siren was steam operated and was located at the "Town Works". I'm guessing that's what they called the public works building way back when. Well before my time.
   / Good morning!!!! #208,767
Happy Birthday to MG and Happy.
82.5F here with a mix of sun and clouds @ 11:00. Clouds increasing this afternoon with scattered thunderstorms some of which may have strong gusty winds. Calling for a high of 83F for the day.
Rain never materialized yesterday.
Got all the summer squash weeded, watered, and fed yesterday. Spotted first zucchini starting to form, have multiple straight neck yellow squash a couple of inches long.
Also watered and fed pole beans and winter squash/cukes on arched trellis. Spotted first cuke starting to form.
Worked some more on working cuke/squash vines up into trellis and securing them with garden velcro. Both doing well:
Worked the soil around the two smallest rhubarb plants and fertilized them with some 12-12-12 then gave them 2 gallons of water each:
Moved recently painted short t posts around to the back.
Got weed block fabric for the final section of arched trellis in place and pinned down.
Set stakes to mark positions of last two short t posts for arched trellis.
Mowed about 1/2 of the front, will need to finish that up today.
Came inside around 17:30 to switch over drink, check spaghetti sauce and hopefully get a shooting opportunity at mama groundhog. She was a no-show ... but spaghetti sauce turned out good after a little doctoring. Made garlic toast and fed downstairs cat.
Put out bait for coon and waited in chair until around 22:00 for him to appear, another no-show.
Feeders did not get filled so that's on the agenda for today.
Friend coming over later with small welding job. Need to go up to the shop and fire up the AC.
Plants on back shelves watered, only 2 winter squash and a baker's dozen tomato plants remain.
Monarch butterfly enjoying the Swamp Milkweed up in the front yard:
Hope everyone is having a decent Thursday.
   / Good morning!!!! #208,770
68°F and .1 inches rain
Got a couple hours mowing in the afternoon. Boy a lot of the far side was over 3 foot tall. Amazing what a bit of rain, sun and time will do. Will continue today.
Sophie found a 1 pot chicken Alfredo she wants me to attempt. This afternoon is our H&F.
Makana is entering a new phase, our bed. She doesn’t always make it 1st attempt, like she misjudges the jump and her lower body kinda crashes into side. Then she tries again
Likes the edge. Has slid off 3 times
Prayers for all
Be safe
Have a great day
2018 Bell B30E 30 Ton Articulated Dump Truck (A55973)
2018 Bell B30E 30...
SCAN TO RECEIVE TEXT UPDATES (A52709)
SCAN TO RECEIVE...
2006 FORD F-150 PICKUP (A58017)
2006 FORD F-150...
2022 INTERNATIONAL MV607 (A58214)
2022 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2018 FREIGHTLINER...
