Ford 5000 power steering. To repair, or update?
   / Ford 5000 power steering. To repair, or update? #1
AntiqueIron
NY
1968 Ford 5000, Gas 8 speed Preforce
My tractor is a pre-force, may of 1968. She has the early style power assist steering, which uses a cylinder with attached valve tucked inside the front bolster under the radiator to add hydraulic force to steering motion. The cylinder, or maybe the lines feeding it, are leaking badly. It needs a full re-pack.
My question is, if I were to buy a post 1970 steering system (pump, power assist column, lines, etc) from a junkyard, would this update be worth performing? Has anyone else done this?
Thank you for reading.
   / Ford 5000 power steering. To repair, or update? #2
I've never done it, but I suppose someone has. Would it be worth it? I guess that depends on how "it" price tags out. It would be a much better handling tractor, no doubt there. It would require the entire power steering column assembly, and probably the front bolster assembly as well, including the pedestal shaft and some linkage. I don't see the need for a different pump. The drag link would probably be a different length, but could most likely be modified to work.
   / Ford 5000 power steering. To repair, or update? #3
I've never done it either but I would think the cost out weighs the benefit. I would consider over hauling the current system. Below are pictures of the front of my 3910 if it helps your decision. Not shown are the actual steering cylinders and the mounting for the trailing arms. Half the trailing arm mounts are cast into the transmission.
Also, if anybody has any tips on getting out the big tapered pin holding the cylinder, I’d love any advice I can get. The current plan is to take an air hammer to the surrounding casting and hammer in some wedges underneath the pin with a BFH.
   / Ford 5000 power steering. To repair, or update? #5
I resealed/rebuilt a 4500 not ling ago that yses the same system. I can't remember how I got the tapered pin out, but it was something similar, just minus the air hammer. The leaks are the easy part. Fixing the play in the linkage could get expensive. I has one part machined to replace a worn guide pin. Works great now.
I’m lucky to not have much play, fortunately. Pin holding the rod end of the cylinder was in good shape- definitely had some slight wear, but hardly any material loss on the pin itself.
Tip to anybody doing this on any 4400/5000 with the 735 loader- jack up the loader subframe, take off the pump cover, via the 4 bolts holding the subframe horns. Remove the pressure side line on the pump, and 2 bolts holding the pump plate to the bolster. Remove 4 bolts holding the shaft adapter to the crank pulley. Push the adapter forward with a pry bar as far as you can on the splines. Put a pair of vice grips on the shaft, and hit them from the side, sliding the shaft back towards the crank pulley. Tilt the pump down so the shaft faces up towards the sky. Slide the pump out.
I also recommend putting a bolt or two back in tying the horns to the frame just for safety. That loader is heavy and cumbersome and I think an engine hoist is nearly essential to do this safely.
Loosened the castle nut holding the tapered pin tonight. I’ve been spraying PB blaster on that all week- I’m looking for all the advantage I can get- sources tell me it’s a real booger to get outta there! 😕
The good news (less good for my wallet) is that now is a great time to replace the water pump, fan belt, steering lines, and power steering filter. (Thermostat would be a good idea too, but I changed that when I did the coolant 2 winters ago)
My local mom n pop hydraulic shop made me a flex line with crimp fittings to replace the existing rubber section of the pressure line. Plan is to cut the tubing with a hacksaw next to the fittings on the old flex line and splice in the new one.
This also brings the advantage of having a replaceable assembly should trouble arise down the road.
   / Ford 5000 power steering. To repair, or update? #7
Pretty sure I heated the tapered pin to get it loose.
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2012 Bobcat E45 Mini Excavator (A55787)
2012 Bobcat E45...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A55788)
2007 Kenworth T800...
2007 Amkus Rescue System (A55787)
2007 Amkus Rescue...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
