Starlink
/ Starlink #4,482
Pay climber to install a Starlink @ top of healthy fir ? :cool:
I know a guy who did that: paid a climber to install antenna over 100' up a redwood tree. That was for WISP (Etheric, Surfnet, or Ridge Wireless).
Good to know the antenna for Starlink can tolerate some movement.
I got my fiber now (Frontier). 500M for $47/mo. Replaced my old DSL (28/2M for $90/mo). Funny thing: does not seem any faster, except for uploading a video to Utube.
/ Starlink #4,483
For most things, 20Mb download is fine. Biggest speed limiter is the server you are accessing.
/ Starlink #4,484
I know several folks who have done just that. Starlink says that they can handle up to 3' of tree sway.
3 feet is impressive.... when I was joking about that, I figured you'd need a mobile version of Starlink, but apparently not.
If a giant tree is moving more than 3 feet in the wind, downloads are probably your least immediate worry !
Rgds, D.
/ Starlink #4,485
Rgds, D.
3' of motion even 100' up isn't a lot, that's like a 5-10mph breeze...
If they can only handle 3' of motion (in how much time? I assume that's 3' over a few seconds) it's not going to be a good time during a decent storm.
I had a T1 line for about ten years, and then the company that was paying for it who I'd worked for during the first seven of those years finally cancelled the service... after that, we had a wi-fi-like connection to a local provider for a while with an antenna about 70' in a ponderosa pine. Not being at the top of the tree, there was a lot less sway at that level.
/ Starlink #4,486
JK (mostly).... but I hang-out here to see what inventive things people are doing, not just on Tractors.....
Rgds, D.
Depending on the service level, you can use it in motion. Plenty use it on boats & some use it while driving. A tree would be more stable than those.
/ Starlink #4,487
3' of motion is nothing to the cone of radiation coming down. Uploading will most likely take a hit though. My head hurts when I try mathematics but 3' of motion on earth is probably many miles at the height of the satellites (~342 miles away).
Edit: Forgot to mention-The satellites are moving too. One revolution around earth ever 90 minutes. That's crazy fast. Far faster than a tree sway.
/ Starlink #4,488
Orbital Fizx calculations..... we're not just a bunch of pretty faces around here ! :cool:
Rgds, D.
/ Starlink #4,489
The beams down and up aren't that tight, but the angular shift would absolutely need to be accounted for. Phased array antennas are accurate, but there are limits. I would remember that the base frequency is 5GHz, so there is ample sampling to update the array target angle compared to wind motion in a tree or an airplane (500+mph...). Since it works in aircraft, anything terrestrial is a piece of cake.
All the best,
Peter
/ Starlink #4,490
Each Starlink satellite is only in view for 15 minutes or less. So the dish has to track it across the sky at a pretty good clip & then sync up with the next one before the first is out of view. Gen 2 dishes were motorized, but only to point towards clear sky. The antenna in all the dishes are phased array antennas that can be steered instantly electronically by a fair bit. Probably at least 30 degrees. Compare that with orbital velocities & driving or even flying speeds become easy to adjust for.
I assume they dropped the motors on the Gen 3 dishes for cost. And the fact that they now have enough satellites it's even easier to have one in view as long as your pointing vaguely towards clear sky.
On a recent camping trip my gen 2 dish kept pointing itself into the trees instead of open sky. Still had 99.9% connection though so I just left it there.
/ Starlink #4,491
Damn I wish mine was that easy to keep happy.
My wife works from home over a vpn, and she will be working on a big spread sheet and it will drop out.
Damn thing says obstructions, but it only shows the slightest bit of red to the east.
Trees are getting bigger every year, I've remounted it 3 times already and getting ready for a 4th time.
/ Starlink #4,492
The company I worked for was consumed by a monster (think Larry E) and we were FORCED to use their internal VPN for a mandatory purpose. Our group was entirely remote all over the world. Our manager procured us all 2nd laptops so we could watch the one connected to the VPN out of the corner of our eye so when the page/app finally loaded we could finish our effort. It was not a moral building experience working for that big name and the recollection of the idiom "Nothing's too bad for the employees".
Yup. VPN does slow things down a very little bit but it's the server and the data/app being accessed that is the choke point.
/ Starlink #4,493
We live in the forest and I have the 2nd gen dish in the best possible place. I get the 'red' interference on the extents of 3 sides. But the dish never loses the connection or has any noticeable speed reduction.
Yup, funny thing about those trees getting a little taller every year. They are the reason I can't add a windmill to our solar in a place that has plenty of air movement 75' up.
/ Starlink #4,494
Just install a windmill with expanding legs……..
/ Starlink #4,496
Fiber is symmetrical...you get the same speed both ways. Most others are asymmetrical, with MUCH slower speeds up than down. When we went from cable to fiber here, I didn't notice a huge difference in d/l even though it was 3x the speed (300 vs 100), but, man do those uploads fly!! Previously only got around 22 up, now it's the same as down.
/ Starlink #4,497
Not with Spectrum fiber.
/ Starlink #4,498
Yes, my Frontier fiber is symmetrical, and I verified that: 500/500M.
I thought fiber was generally symmetrical, but apparently not with Spectrum. Good thing most customers don't upload videos.
/ Starlink #4,499
With g-pon it's not symmetrical. The company can make it symmetrical, but it's something like 2.5g down and 1g up. Very few people need 500 up.
/ Starlink #4,500
We've had a number of thunderstorms come through lately. Quite often the Dish TV receiver loses connection & switches to internet streaming to prevent program interruption. Starlink is our only ISP and has never failed to provide an uninterrupted continuation of the program. No buffering delays or glitches. It may well be impacted, but not enough to be noticeable in this case.
2007 Toro Z-Master Zero Turn Commercial Mower (A64553)
2007 Toro Z-Master...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
