Help me decide, 3 trucks I need to pick 1 from.
/ Help me decide, 3 trucks I need to pick 1 from.
Sorry should have written 2023 Ram Bighorn 4wd with 5.7 diesel.
Looking it up it has a 19,980lb towing capacity link .
liked the Ford for an aluminum body too, will not rust out. But, if you can't have a working engine, then it's useless.
That's what I'm afraid of.
Thanks for the input.
/ Help me decide, 3 trucks I need to pick 1 from. #13
Tow capacity and payload listed are a joke. It’s for a bare bones regular cab 2 wheel drive to get those numbers. Towing your trailer with a diesel won’t be a problem but I would look at the payload of any truck you are ready to buy, it’s on the door jamb sticker for the way that truck is actually equipped .
/ Help me decide, 3 trucks I need to pick 1 from. #14
Background:I'm retired. I've been going through the process of trying to determine what truck to add to my fleet. The truck will be used in Virginia and Mississippi. It's prime purpose will be to gather dust and suck up parking space. Occasionally, maybe 5 times a year I'll drive it from Va. to Ms. towing a 10K trailer down I81, I40, I75 and getting to northeast Ms. and then after a month or three, drive back. It will carry 2 passengers, me and my wife.
I've been making this trip with about this frequency since 2011 mostly with a 2002 Ford F350 7.3, CC, dually and it's crazy I know.
But the dually is getting "long in the tooth" and I'm concerned about it breaking down.
I missed out on the deals last January and the Tariff threat kicked in and prices jacked up. But now they have come back down slightly.
Also I looked at 5L F150's and they cost almost as much.
So I've narrowed my choices down to 3 vehicles.
2023 Ram Bighorn with 5.7 diesel < 300 miles ~53K
Warranty mostly used up sitting on the lot
2024 Ford F250 XL w/ 6.7 0 miles full warranty ~56K
2025 Ford F250 XL w/ 6.7 0 miles full warranty ~60K
To me the 2024 is the sweet spot.
/edit - what would you pick?
From post #1 description, the Ram is a 1/2 ton small block diesel and the other 2 Fords are 3/4 ton bigger block diesel trucks. Also the ram has 300 miles. We don’t know the miles on the Fords.
Try comparing more comparable trucks.
Or, just buy a Ford.
A 6.7L Cummins is probably a bit too much truck for you. 😁
Honestly, from the description of what you use a truck for, you’d be better off with a gasser.
Today’s diesel trucks, with their DPF & DEF systems need to be driven often and pushed hard, or you could have emissions problems.
/ Help me decide, 3 trucks I need to pick 1 from. #15
I'm a long ways away from making a similar decision. I need a bigger truck, but it's not something that I'll use every day, and it might sit for a month or more without being started.
Modern diesel engines scare me because of how expensive they are to repair, and how often I hear about DEF issues. Just finding a mechanic to work on them can be challenging.
The other issue, and something that I'm worried about with a new diesel engine is what happens if it sits for long periods of time? Does the DEF go bad? Does it have to be run on a regular basis to keep the fuel fresh? Just keeping it connected to a trickle charger is all I want to do when parking it. Anything else seems excessive.
My current dream truck is a F350 dually with the Godzilla gas engine.
From what I'm reading and watching on YouTube, it gets about the same mileage as the diesel does when empty, but really goes through the gas when loaded heavy. For the few times a year that I would be hauling a heavy trailer, I can deal with the cost of gas to get it done.
/ Help me decide, 3 trucks I need to pick 1 from. #17
Diesel trucks with DEF/DPF that sit long periods or used for short trips without pulling a trailer, tend to get soot build-up in the DPF.
I think you are on the right track with the gas engine, but remember the Cummins 6.7L gasser is on its’ way. If they put it in the 2500-5500 trucks, it’ll revolutionize gas engines. It will consume less gas, run at lower RPM while providing similar torque to the gas guzzling V-8’s.
/ Help me decide, 3 trucks I need to pick 1 from. #18
I forgot about the Cummins gas engine that's coming out. I saw a few videos talking about it, but since it's not available yet, I haven't put any thought into it. Fortunately, I'm in no rush to buy anything yet, I just enjoy learning as much as I can before I make a decision to go into debt.
/ Help me decide, 3 trucks I need to pick 1 from. #19
2023 Ram Bighorn with /edit- 6.7L
Not sure what the warranty situation on Ford is today, but in 2020, when I bought my Ram, Ram had full 5yr powertrain warranty on ALL driveline components. Ford only had 5yr engine warranty on powerstroke engine. Rest of drivetrain was 3/36. That was a huge difference in the confidence Ram had on their powertrain compared to Ford.
That may have changed.
300,000 miles on a 2 year old Ram means there’s no warranty left.
/ Help me decide, 3 trucks I need to pick 1 from. #20
6-cylinder turbo charged gas engines are going to render the V-8 gas guzzlers impractical and obsolete.
They will make better torque at lower RPM and consume less gas.
Turbochargers last a long time and require little maintenance.
84''Skid steer bucket (A61567)
84''Skid steer...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2025 AGT STSD10 72" Grain Drill (A60463)
2025 AGT STSD10...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
