   / Your last generator Maintenance Run #7,551
Great when A Plan Works Out Well, isn't it...... Back Muscles usually take a while to normalize after "tweaks", so Paid For, right there !
It's not just California...... plenty of areas are affected by the same Financial cutbacks, which reduce tree-cutting. Our societal energy needs are going up (long conversation right there....), but that notwithstanding, seeing these problems today underlines how significant the accomplishment of the original grid build-out was, AND that it was paid for Back When.
Rgds, D.
I've been considering an EV, but this aging grid is cause for concern. The idea of using a diesel generator to charge an electric vehicle just seems ridiculous. :rolleyes:
As you said in an earlier post, I too have learned a great deal from this thread. It was information I learned here that contributed much to my project. Thanks for starting it! (y)
   / Your last generator Maintenance Run #7,552
You have the unit I had designs on… just the right size and diesel.
I had been looking at these Kubota Lowboys for a couple of years before I finally pulled the trigger. The $$ per KW cost is a bit high but I like the Kubota name, and there is a dealer just a few miles away. I was concerned at first about the capacity of the GL11000, since it replaced my old Baumalight 12.5K PTO model. I considered the 14K model but I never came close to stressing the 12.5K though, so I don't regret the choice. I also liked the fact that the wheel kit was available for the 11K, but not the larger 14K.
Funny you say that........ plenty of high-visibility public EV projects charge on diesel (meaning All the Time), due to lack of infrastructure.
I like dzl/elec in general, and that would sit towards the top of my consideration list for a hybrid. Not just me..... there have been interesting military dzl/elec projects.... something like a scout vehicle for example - you have long-range capability, but can select electric for quiet/low signature conditions. Locomotive engineers figured out the attraction long ago, but only got around to adding batteries quite recently.
This thread has been a lot of fun, and only exists due to the extensive documentation and great pictures supplied by countless people. I've learned a ton, hanging around here.
Rgds, D.
   / Your last generator Maintenance Run #7,554
Rgds, D.
My comment was meant mainly as a joke. I would buy an EV for "green" reasons and running a diesel to charge it would defeat that purpose.
Sure, there are many practical industrial / commercial diesel-electric applications, but I'm talking about a small compact vehicle for around town use, not a hybrid
If I were going to regularly charge a small electric vehicle with a diesel generator, I would just buy a diesel powered vehicle instead.
Again, it was mostly a joke.
   / Your last generator Maintenance Run #7,555
No better better a test loadbank for a generator than an charging EV 🤣 In all seriousness an electric car could perform a useful task while a backup generator is running for actual backup reasons: The EVSE (the bit on the wall, incorrectly called the charger) tells the car how much current it can safely draw. The current signal can be varied on the fly and the car must follow that direction.
So by means of a current transformer or interfacing with the generator control system you can have a load that uses excess generator capacity while loads are light to prevent wet stacking and the likes - My car can also deliver 7kW of AC to allow for using banked electrons when you want to sleep :D We do this at my friend's off grid holiday house. The car happily runs everything for two or three nights which is about the frequency of resupply missions to the nearest town with fast chargers.
   / Your last generator Maintenance Run #7,556
Depends on the vehicle and the charger, The Chevy Equinox EV with the factory charger is a 32 Amp draw for 7.7 Kw.
   / Your last generator Maintenance Run #7,557
But you can turn it down, all vehicles that are compliant with J1772 can charge on as little as 6A generally on either 110 or 220V
   / Your last generator Maintenance Run #7,558
Yes, 120 volt setup can be used at 6 amp or 12 amp, the 240 volt setup can not be adjusted it will max out at 32 amp with no user ajustability.
   / Your last generator Maintenance Run #7,559
Factory supplied EVSE sure, but there are adjustable options on the market
   / Your last generator Maintenance Run #7,560
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2005 Ford F-150 Pickup Truck (A55852)
2005 Ford F-150...
CAT CS563 (A47477)
CAT CS563 (A47477)
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
