Removing gasket cement from inside of toilet tank - how?
   / Removing gasket cement from inside of toilet tank - how? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Looks like the previous owner put gasket cement on the toilet to tank bolts on the inside of the Toto tank. I've 4 tanks to do. I don't want to chip the tank. Any recommended solvent that will take it off?
I need to get a good seal on the connection.
   / Removing gasket cement from inside of toilet tank - how? #2
Why do you need to do four tanks, and what is the goal? Do they all leak?
I think of gasket cement in the context of boilers and wood fired stoves.
Are we talking about here? Does it look like JB Weld, silicone, plumbers putty, cement?
A little more detail, and even a photo could help.
All the best,
Peter
   / Removing gasket cement from inside of toilet tank - how? #3
Roughly $480 to get 4 replacement tanks...for me, my aggravation would be worth right about that much.
Turn the existing ones into planters.
  • Good Post
Reactions: JJT
1.Why do you need to do four tanks, and what is the goal? Do they all leak?
2.I think of gasket cement in the context of boilers and wood fired stoves.
All the best,
Peter
1. Four toilets, all put in about the same time and I suspect by the same person with the same methods.
2. It looked like a wad of black sealant. Like I've put on wood stoves.
The only advantage of a replacement tank would be it's clean. If I find a solvent that would work it should be quick.
I don't need to spend $480 for planters, I could use it to buy tractor parts.
   / Removing gasket cement from inside of toilet tank - how? #6
Wire brush on a drill motor!
They come in a variety of sizes and confidurations
Yeah, that may be the next step. I just was trying to limit it to solvents, elbow grease and copper pads.
Power tools raise the possibility of porcelain breakage.
   / Removing gasket cement from inside of toilet tank - how? #8
That toilet tank is tuff! Just don't bang it.
If solvents worked, (approved and available ones that is) then they would not serve as "all purpose sealants".
Those brushes come in all grades of wire size.
Weiler is a useful reference
   / Removing gasket cement from inside of toilet tank - how? #9
$119 for a brand new toilet - why replace parts when you can get everything new?
Because the
toilet is a Toto elongated.
IF a little spray of brake cleaner, or ether, or vinegar or something else would do it it would be a lot cheaper and easier.
Apparently the TBN knowledge base hasn't kicked in yet.
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
2019 Caterpillars 299D2 XHP SKIDSTEER (A51242)
2019 Caterpillars...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
