You Know You Are Old When
   / You Know You Are Old When #5,521
Not to rant, but it's downright embarassing what people wear in public, these days. Even at church, I see folks in everything from ripped jeans to tank tops.
It's not that hard to throw on a pair of khaki's and a shirt with an actual collar. :rolleyes:
Working in the shop or yard, I'm the dirtiest grease monkey you'll meet. But I do at least clean myself up and put on clean un-ripped clothes, before heading out somewhere.
Reason some 12 I try to never leave my place. Right now it's sneakers, socks and shorts, that's it. Makes finding the ticks easier.
   / You Know You Are Old When #5,522
Sneakers? Way too dressy. Flip-flops here. :cool:
   / You Know You Are Old When #5,523
I loose the flip flops in the mud, rock and manure 🤣
I do put on boots when it's really wet, and ragged sleeveless shirt to ward of rain as needed. :unsure:
   / You Know You Are Old When #5,525
I go barefoot as much as I can, but for those times I can't I'll wear what my wife calls my swamp sneakers. A pair of sneakers or slip-on shoes that hasn't been presentable for a good 10 years but still kinda protects the bottom of my feet. Strictly around the property, she'd have a fit if I wore them in public.
   / You Know You Are Old When #5,526
Bare foot is ok in lawn, unless you are in the south and have sand spurs and fire ants....
I spend more time in the woods than lawn by a long shot.
   / You Know You Are Old When #5,527
I did that with my mower when it was time for the yearly maintenance over the Christmas break. I checked the drawer where I normally keep keys, and they weren't there. But I did not have to hunt for them, as I knew right away that I'd find them in the ignition with a dead mower battery. Doh!
When I park the mower at the end of the season, I close the fuel cutoff valve, and just let it run itself dry. I usually remember to retrieve the key from the ignition after that, but apparently forgot last fall!
I also normally install a battery tender, but since the mowing season ran late and I knew I'd be moving it again for maintenance in just a few weeks, I hadn't bothered with that last fall.
I quit using tenders a while ago. All my equipment from diesel powered lawnmower to the wife's gas powere ZTR to the electric start pressure washer, all have bayyery disconnect switches so when I park them, the batteries are taken out of circuit and when it comes time to use them again, I simply but the starting battery back in curcuit and off they go. Flooded cell batteries as a rule, only loose less that 10% of their capacity when standing idle per month. Isolator switches and me are good friends.
   / You Know You Are Old When #5,528
Barefoot on our lawn is a almost a sure bet to walk in some dog pooh.... Not something I find exciting...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2019 CAT 259D (A60462)
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
