Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #25,291
I carry an axe in a holster on my tool belt for pounding wedges.
That's definitely the way to go, when felling.
But when cutting logs on the ground, I just carry two wedges, one in each back pocket. If you choose the time to insert them appropriately, they never need more than a tap or two, usually using one wedge to tap the other into place.
I always have a hatchet in my chainsaw toolbox, when I need to whack a wedge harder, but it's very rare I need to do that.
   / Tractors and wood! Show your pics #25,292
The row of split wood in the back ground was left over from last year that would not fit in the shed. I have moved that into the shed.
The pile of blocks/rounds cut from logs I pulled out last February are now split and air drying. They should fill the rest of the shed.
If I need to top off the shed I still have a half cord on my trailer.
gg
Stacking once is imperative to me. I modified my process accordingly.
I used to stack wood in the SxS, then run the SxS to the barn stack it in the pole barn, then when I needed firewood, stack it back into the SxS to take it to the attached garage.
Then I started using totes and only stacked into totes and brought the totes into the garage.
This year, I am trying a way that requires no stacking at all. When I get on my computer I will post some pictures.
   / Tractors and wood! Show your pics #25,293
When cutting logs on the ground, I still keep an axe with me, since it's handy when using the wedge to lift a log off the ground, as described about 4 posts up. Normally, I'll roll the log, but occasionally, it's easier to drive the wedge in to lift it than it is to roll it.
   / Tractors and wood! Show your pics #25,294
Thanks Hoobie - that's just the kind of info I was looking for. I would only use it for small rough projects. Things I do now by snapping a line and going totally free hand.
gg
For a lot of rough work your freehand method is fine....even better. The Alaskan gives pretty acceptable dimension results but is somewhat limited in length of product as I mentioned without considerable fussing. The snap line / freehand idea is limited only by length of tree, length of line and chainsaw skills.
   / Tractors and wood! Show your pics #25,295
Working on the wood pile. It's not pretty but it will keep us warm for a couple of years. Used to be a nice shady spot but we had a low snowfall last spring that took out a few nice oaks. The picture is deceiving, there are two piles of logs/limbs. And I haven't even cleaned up the tree behind it yet. I don't like to wait until the summer heat to do the firewood, but had to get all the other spring chores out of the way first.
   / Tractors and wood! Show your pics #25,296
The picture is deceiving...
Downed trees are second only maybe to waves at sea, in never looking as big on film as they are in person.
Looks like a lot of wood, although not a whole lot of it is straight, so you have some work in splitting it and making it stack!
   / Tractors and wood! Show your pics #25,297
I like that... waves at sea. Maybe why I don't take many pictures.
Yes, it's twisty live oak mostly. I've been doing this for a few decades, I know what I'm in for. I prefer Black oak, but I get what falls. It actually splits and stacks pretty well, although Im starting to use more toats and that makes it easier. It all burns well and when I do have strait pieces it makes decent kindling. But I won't turn down cedar for that when its available.
   / Tractors and wood! Show your pics #25,298
Did a little scrub brush and pine clearing so they don’t choke out the better trees and cleaning up the perimeter a bit. I have to say the DR chipper has exceeded my expectations. Makes short work of the stuff I’m putting through it.
   / Tractors and wood! Show your pics #25,299
I've had this load of wood on the trailer since mid April so this afternoon was past time to work it up so I can use the trailer for something else.
Over the winter I made the left hand stakes so they would fold down and built the cutting table. This is the first time I used them together.
It started out warm and cloudy but when the sun came out it seemed like a good time to stop.
Just for fun I used my 47 year old HomeLite Super XL that I bought new in 1978.
gg
   / Tractors and wood! Show your pics #25,300
Nice! Only thing I was buying new in 1978 was Tonka trucks. :p But I did own a 1970's Homelite Super EZ Auto for many years.
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
71055 (A49346)
71055 (A49346)
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
