LOCKING 54 High-Capacity Mower Deck Wheels PN: AM148127
   / LOCKING 54 High-Capacity Mower Deck Wheels PN: AM148127 #1
sriddle1
SW New Hampshire
ACTIVE: JDX730 DAYS GONE BY: JD3010, JD790, JD425
Hello, own a X730 and having lots of problems keeping the Mower Deck wheels spinning freely, plenty of clearance when the deck is down so not in constant contact (as they should be), they just keep locking-up then dig-in to the lawn. I do keep them lubed with the JD synthetic grease, perhaps there's an alternative design out there.
   / LOCKING 54 High-Capacity Mower Deck Wheels PN: AM148127 #2
Is this the front gauge wheels digging in when turning or the wheels themselves stop turning?
If front digging in when turning try running them one hole higher than the rears. That stopped that problem on my X540 with 54” deck.
oldnslo, Thanks for the response, I've pulled them off 3 times now, injected them with WD40, manhandled on a vice to get them free and also re-lubed with synthetic but I keep going back to the lock state. The wheels are high enough but occasionally they do hit the ground (as designed to do) and because they don't spin the dig happens. I'm looking for some replacement wheels, but I see JD only sells the whole kit, pretty $$$$$.
   / LOCKING 54 High-Capacity Mower Deck Wheels PN: AM148127 #4
I take it that the wheels that you have do not have bearings in them. Here is a part that appears to be compatible with your machine. Pricy but with bearings:
   / LOCKING 54 High-Capacity Mower Deck Wheels PN: AM148127 #5
Off the wall thought but…..Is the lube the problem? Just wondering if the lube is possibly causing the plastic wheels to swell or collect dirt and then seize. My mower probably has similar wheels and they have never been lubed. Original owner had one of 519 carts that wore out the right rear from carrying all the blower weight but none of them seized.
   / LOCKING 54 High-Capacity Mower Deck Wheels PN: AM148127 #6
I too suspect the grease is the problem, if the wheels are assembled correctly. Clean them up so they are free of grease and assemble dry.
If that solves the problem, let us know back.
Thanks Richard, yes, I went into the JD Parts Catalog and see that is the replacement part, pretty expensive. I reached out to see if anyone else was having this problem.
Thanks oldnslo, there are grease nipples, so I've been using the JD Multi-Purpose synthetic Grease - TY25744, seems to hold out better than the non-synthetic. I guess I'm going to have to take it appart to see what's going on.
oldnslo, Thanks for the response however the grease doesn't come in contact with the plastic. I've been busy with other projects, I did lift the wheel to a very high point to it doesn't hit, minimally affects the cutting. I'll be tearing it down in the next week or so, I appreciate the posts so far. I was hoping for an aftermarket part but NOTTA..
Brent 420 Grain Cart (A56436)
Brent 420 Grain...
Freighliner Tender Truck (A56436)
Freighliner Tender...
7ft Metal Gulf Gas Pump (A57454)
7ft Metal Gulf Gas...
HiSpec ST205/75R15 Tires (A56860)
HiSpec ST205/75R15...
(40) Collectible Watches in Box (A57453)
(40) Collectible...
pressure washer, and trailer (A56859)
pressure washer...
