ATV mounted sprayer
/ ATV mounted sprayer #1
alexinPA
NE PA (Lackawaxen)
Kubota B7800
I got an old North Star 26 gallon atv mounted sprayer. It doesn't have an agitator.
How can i mix glyphosate with water in the tank? Just to fill half tank, add required
amount of glyphosate, and finish with water? Looking for suggestions...
/ ATV mounted sprayer #2
I normally fill 1/3 tank of water, put the glyphosate in and fill the rest of the way. Not sure if there is much more you need to do. If your concerned then use a spray want to agitate the water more when filling.
/ ATV mounted sprayer #3
Real chemical gloves first...always.
I have the exact unit. I love everything about it except the lid that just doesn't want to properly thread but whatever. Glyphosate will go and largely stay in suspension. I do what Sportsman762 does but in the end I use an ash shovel but you could use any large scoop or paddle and stir with a gloved hand of protection. You can watch it improve the mixing as the color changes.
For chem that doesn't stay in suspension, I stir and have a dedicated mixing pump that pulls from the opposite end of the tank and then vents straight down into the tank...from the hole plug that replaced the lid (not depicted in photo). Now there's two round wood plates screwed together. One fits inside the lid hole; the other just sits on the top with a small pump mounted to the top of the new "lid". This seems to keep chemicals like pre-emergents suspension along with thrashing the thing around a bit with "drunk weave" driving. BTW, the quick disconnect is great for separating the tank from the spray assembly. The TeeJets are wonderful; they will tolerate about 125 psi IIRC but they pop at 5 psi which means they dribble what's below the internal valve but doesn't allow the entire hose to drain.
/ ATV mounted sprayer #5
Wouldn't accelerating then stopping in quick, jerky motions mix the contents? Bumpy or hilly terrain might do the same. The tank would need to be sealed when you do this, of course.
Thanks for your help, internet expert.
/ ATV mounted sprayer #6
Some good advice already delivered.
If readers haven't already bought a tank, I recommend one that mixes on exit. There's a separate tank for your chemicals, so mixing is easy and you can control the concentration. Extra chem tanks make it easy to switch chems, too.
/ ATV mounted sprayer #7
If it doesn't have a hand/spot wand, add one. Stick the sprayer end into the tank and run it a few minutes. I always put about 3/4's or nearly to full water in the tank before adding glysophate. When adding water it foams up real bad so less room. I use the spot wand to agitate the mix, never seen any issues when doing this of the mix separating afterward.
One guy recommended using boat bilge pump inside the tank. How's that idea?
/ ATV mounted sprayer #9
Where you going to pump it to? Just back into the tank. I could see that working great. THey move about 500gph and up.
/ ATV mounted sprayer #10
See trailer and box mounted sprayers up for sale on FB very often. With and without boom. I may need one for Garlon.
NorthStar ATV Boomless Broadcast and Spot Sprayer, 26-Gallon Capacity, 2.2 GPM, 12 Volts​
Item# 99906
This is a carousel with one large zoomable image and a track of thumbnails on the left. Select any of the thumbnail buttons to change the zoomable image on the right. If a thumbnail is a video or 360 degree image thumbnail, or the last thumbnail in the list, the button will open the product media modal.
Click or Tap image to Zoom
$269.99
Reg $299.99Save $30.00
Order today to get this price.
/ ATV mounted sprayer #11
I've been using the North Star tank for 20 yrs. I put the chemical in a small amount of water and mix with the garden hose as I fill then spray. Works great.
/ ATV mounted sprayer #13
Exactly what I do with my ATV bed mounted sprayer and you driving and spraying keep it mixes. My big 3 point mount 250 gallon spray rig has continuous agitation provided by the pto driven roller pump an it's adjustable as well. Glyphosate when mixed in the tank will stay mixed for a long time anyway. Other chemicals, not so much.
Chemical gloves when mixing or no touch. I do the no touch method myself, followed by a rinse and a tad bit of Dawn dishwash detergent and another rinse. Don't forget to remove tnd clean the Tee-Jet strainers located at each spray head either.
/ ATV mounted sprayer #14
My ATV sprayer use to have a mixing valve on it but I use that for a boomless nozzle. I find just driving around a bit mixed just fine.
/ ATV mounted sprayer #15
I can see the return port that they use for agitation in that photo above. I know, because I have the same unit, except I have the 12' boom attached
Your 26 gallon doesn't have it?
/ ATV mounted sprayer #16
That's how I mix my 35G sprayer. I have a special hose with no end fitting and city water pressure of 100PSI.
I don't have a UTV/ATV, so I put the tank on a 3-pt carrier I made and run wiring to the tractor battery.
I haven't tried this in my new bigger tractor yet.
/ ATV mounted sprayer #18
You guys using these sprayers on a atv. Is your stator keeping up?
I don't understand the question. Mine sits in the bed and runs off of a rv battery. I could hook it into the UTV power, but I prefer to keep 'em separated. (Queue the music)
We usually use the wand, but it has a boom, too.
2018 CATERPILLAR 315FL CR EXCAVATOR (A62129)
2018 CATERPILLAR...
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN# 7FWBE1622T1037829 (A61166)
2026 Steel Pines...
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
Bradco 84in Hydraulic 6-way Dozer Blade Skid Steer Attachment (A61567)
Bradco 84in...
2019 Chevrolet Express Box Van, VIN # 1HA3GTCG9KN007839 (A61165)
2019 Chevrolet...
(INOP) CUB CADET 1810 LAWNMOWER (A62131)
(INOP) CUB CADET...
