John deere 2955 will not turn over unless lights turned on
/ John deere 2955 will not turn over unless lights turned on #1
scruffy335
Ford 335
My JD 2955 will not turn over, unless I turn on the light switch, then it starts fine, but sometimes
turning on the light switch does not help either. It is like no click, no nothing. I put in a new switch and it worked for 1 month, and
now it only cranks sometime when I put the light switch on. I did put a complete rebuilt starter on it. -- any ideas will be appreciated.
thanks for your help,
/ John deere 2955 will not turn over unless lights turned on #2
Will your lights come on with the ignition in the off position?
/ John deere 2955 will not turn over unless lights turned on #4
I would guess it’s a loose connection and you moved it while installing the. New switch. Just a guess
/ John deere 2955 will not turn over unless lights turned on #5
I suggest to relocate battery ground cable from attaching to sheet metal to attaching to engine block. Check clean/tighten all 4 battery cable connections. Check operation of starting relay if applicable located in front of firewall
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
Giyi GY-TB47 Forklift Telescopic Boom (A60463)
Giyi GY-TB47...
2020 DRAGON ESP...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
2024 GREAT DANE FREEDOM LT FLATBED TRAILER (A59823)
2024 GREAT DANE...
