JD425 - Mower deck/PTO won't engage
   / JD425 - Mower deck/PTO won't engage #1
BrycePoole
JD 425
Symptom:
On my JD 425, the electric clutch to the PTO that drives the lawn deck is not engaging fully. I have the parking brake off. When I pull the PTO switch up, the lights on the dashboard for front & rear PTO light up. But, I do NOT hear the normal screech (I assume the screech is the electric clutch engaging). I do see the rear PTO spinning, however. If I remove the mower deck PTO arm, I can see the front PTO spinning, but if I re-install the PTO arm, it's not strong enough to spin the PTO arm/mower deck. I am looking for help on why the clutch is not engaging fully.
Background:
This is a used JD425. I have had it for two years. I have been using it to mow weeds and tow a yard trailer. I love it! The PTO/mower deck has always engaged and did all the way up to the following change.
The change:
I was annoyed at the seat switch and not being able to hop off and on the tractor without first engaging the parking brake. When picking rocks, this was a major pain. So, I added a toggle switch in parallel with the seat switch that temporarily overrides the seat switch. (Turned on, it overrides the switch. Turned off, it restores the switch to “stock” behavior). To do that I tied into the lines near the seat switch. The new toggle switch is working as expected. High-fives all around!
With the toggle installed, now it won’t engage the PTO (even if the parking brake is off and the PTO switch pulled). I racked my brain to think what else I touched in the process. Well besides splicing the two lines, I pulled apart the X1 and X2 connectors and then reconnected them. Given how dirty they were, I assumed this could be the issue. So I took them apart again and sprayed electronic cleaner on them. I also filed the flat connectors with a small file with the hope of making a better connection. No dice. It made no difference. Still no PTO electric clutch engaging.
I am hoping someone more knowledgable than me can walk me through what I need to check to get the PTO to engage. Help!
   / JD425 - Mower deck/PTO won't engage #2
Did you check the fuse?
   / JD425 - Mower deck/PTO won't engage #4
There is a fuse? Where would I find said fuse?
Under the dash, behind the battery. I think there are only 4 or 5 fuses in the block, I'm sure one of them will be for the PTO.
   / JD425 - Mower deck/PTO won't engage #5
per the Deere TM1517 service manual the 425 has a hydraulic PTO clutch that is operated by a solenoid valve. There are several pages in this manual on trouble shooting diagnostic procedures.
Does the PTO indicator light illuminate on the dash when request for PTO to operate? If yes then fuse is good per service manual.
I think the PTO solenoid valve is on the rear of the transaxle and should have 12 volts coming to it when PTO circuit is active.
If no power to that solenoid then will have to start further diagnostic procedure.
The PTO indicator light for the front & rear PTO on the dash come on. I found the fuses on the control board. I tested with a multi-meter and they are all good.
There is also a green and red LED light on the control board. The green light comes on with the key and the red light comes on with the PTO switch. I understand that is what we want to see.
I finally found the PTO solenoid and tested it. When the key is in run (engine off) and the PTO engaged, the PTO solenoid gets battery power. How do I proceed further? Does this mean the solenoid is bad? Does the rear PTO affect this at all? I should also mention that this has the rear PTO option.
A quick thanks to everyone that has added to this thread!
Honda UTV (A56859)
Honda UTV (A56859)
TANK MANIFOLD (A58214)
2013 Freightliner M2 Box Truck (A59814)
2013 Freightliner...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
