RS1400 Tiller. Where do I buy the wheel bearing for a tailwheel?
   / RS1400 Tiller. Where do I buy the wheel bearing for a tailwheel?
and there is a second one,
Wow, that second one even has the decals showing alternate tine mounting for flat till, center mound, etc. Thanks! My decals were (barely) legible when I bought the tiller in about 2006 but are gone now.
Yep that's the twin to my RS1400. Mine looked more weathered than that when I bought it in about 2006. I had asked for the cheapest one they had. Surprisingly, included for the $200 was a set of new tines. I've never needed to install them. It has always been reliable, I got a bargain.
I went all through the tiller today. Drained the inevitable condensation water (couple of ounces) from the bottom of the gear case. Opened and checked the bearing on the far end of the tine axle, that I had replaced in my initial setup. Fluid levels ok. Lubed the driveline expansion joint so now it slides easily, it had been gummed up. Likewise the unlock pins at each end of the driveline, and the tailwheel swivels. All had been gummed up and stiff. It's been a while since I maintained it.
And I tried mounting the tiller with just the YM186D's normal top link instead of the special 'bridge' needed on the YM240 that gets the tiller clear of the tires. This works, after adjusting the depth wheel to lift the 'training wheels' as high as possible. I may not be tilling full depth but the little YM186D (15 PTO hp) is working hard, needs full throttle and still can't hold rpm occasionally, so this is as hard as I want to work it.
Then I went out and did something boneheaded. Tilled blackberry jungle without mowing it first. :rolleyes: This got so many canes snarled around the tines and shaft that it took hours to take them out. I'll start another thread here with a photo, titled something like 'Don't Do This!' :p
   / RS1400 Tiller. Where do I buy the wheel bearing for a tailwheel? #13
California,
Did you get the bearing changed and where did you get the bearing?
Thanks!
Travis
   / RS1400 Tiller. Where do I buy the wheel bearing for a tailwheel? #14
California,
Thanks!
Travis
McMaster-Carr, Grainger, Home-Depot, Ace Hardware, NAPA, etc.
If you know the bearing root number, you can look at the types available for various improvements too.
Like stainless, double sealed and lubricated bearing. (y)
   / RS1400 Tiller. Where do I buy the wheel bearing for a tailwheel? #15
Fredricks RS1400 Tail wheel parts.
   / RS1400 Tiller. Where do I buy the wheel bearing for a tailwheel? #17
You don't need the wheels I sure didn't. Pic. 1st. pass for the season 2nd with the NTM. RS1400 Tiller. Mothers garden she used a Briggs & stratton walk behind. Yrs Ago last Tiller they had and we had to Dig it out of a back Warehouse. It did have brand new tines! Was told I wouldn't need the wheels and it was true for my use.
Yes. Mine has the wheels and single-side 'fork' as shown in bmaverick's post #10 above. So there's a pair of these 6002 bearings at each wheel.
I didn't replace the wheel bearings for my recent tilling project. Packing in grease restored smooth rolling. It rolls true. There's something in there that was binding, when it was dry. Now There's just an infrequent momentary crunching sound as it likely rolls over a bearing race fragment or something.
I should replace those bearings but I'm not going to until a quieter time.
   / RS1400 Tiller. Where do I buy the wheel bearing for a tailwheel? #19
I was in Tractor Supply today. Plenty of bearings to be found. A bit pricey vs online shopping with free delivery.
Sometimes Ebay has the best prices of all.
I recently got a 'check engine' light on the 2005 Ford Focus. The O'Reilly counter guy scanned the car and found 'excessive voltage at the fuel rail pressure sensor'. I'm an old points&condenser generation mechanic. Never heard of that part.
O'Reilly's price for the sensor was $90+. So I told him I would first try disconnecting the battery to see if that would clear the Check Engine Light.
I studied the project on Youtube and bought the sensor on Ebay for $16.99. Claimed genuine Ford OEM and the sealed plastic bag looked authentic. Maybe counterfeit? At any rate likely the same replica that O'Reilly has for $90. The one I took out had Bosch logo and some text, this replacement had no markings at all.
Installing it took 5 minutes. No more error message. Quality of that part looked excellent, and is likely comparable quality to the replica parts we get for our Yanmars. It pays to comparison-shop!
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
CATERPILLAR 304E CR EXCAVATOR (A51242)
CATERPILLAR 304E...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
KUBOTA M6800 TRACTOR (A51243)
KUBOTA M6800...
