gate or mobile barrier to block access to private road agricultural land
   / gate or mobile barrier to block access to private road agricultural land #1
hybris
Member
italia
SAME Minitaurus 60 dt
gate or mobile barrier to block access to private road agricultural land.
hello we will have to block the entrance of an agricultural land either with a metal gate or with a revolving barrier. currently the entrance is blocked by two vertical poles and a metal rope. any suggestions maybe using recycled materials iron for concrete reinforcements or metal pipes for scaffolding thanks. measurements are road width 4 meters I have to make the pillars floor stand hinges and the latch thanks. any creative economic idea?'
   / gate or mobile barrier to block access to private road agricultural land #2
Similar to your drawing, make gate triangle with smaller triangles in middle for support. Make sure to dig big hole and use concrete to fill the hinge pole. Bigs forces will be trying to tilt pole when gate swings. Use pipe for gate as concrete reinforcement is not rigid for its weight
   / gate or mobile barrier to block access to private road agricultural land #3
Just purchase a couple tube gates, set the stantions and lock them together and hope the tresspassers will be discouraged.
Have that same issue up north on the hunting property and I've had to replace the gates more than once but I take solace whomever the trepassers are, they had to 'work' at it. Much less frequent that before now that the locals all know we own it and we discourage tresspass and I'm always armed up there anyway and they all know I have a very short fuse as well. Tube gates are inexpensive and it you set the swing posts in concrete (pipe), they don't disturb them, just the gates as the posts are too much work for them. I have it posted with a sign full of bullet holes as well so they get the message. They will still tresspass but less frequently it appears to me. Don't have that issue here on the farm adjacent hay fields, because the north property line is a creek that is quite below grade and they don't want to get their feet wet, just tresspass. I do get 4 legged tresspassers anyway. They get dispatched on sight.
   / gate or mobile barrier to block access to private road agricultural land #4
Only suggestion I would make is a buried anchor with an adjustable stay (turnbuckle) on the back side of the gate hinge to adjust/prevent for sag. Years ago I mounted an 8'± wide gate similar design to yours. It was anchored to a vertical piece of 8" I beam buried 8' or so and it still sagged. I was lucky that on the back side of the hinge we had placed some multi ton boulders to stop people going around so I just drilled the rocks and used a chain and turnbuckle.
Why such a heavy beam you ask, I worked for local DOT and it was a recycled bridge support beam and we happened to have an excavator handy so figured what the heck dig it deep and it won't sag....wrong LOL.
   / gate or mobile barrier to block access to private road agricultural land #5
Pre made tube gates don't sag as they aren't that heavy to begin with. I own and operate a machine and fab shop and I'd never fabricate ANY gate simply because the pre made ones are so much cheaper, much lighter and at some poibt your tresspassers will destroy your handiwork anyway. Why bother. Just purchase a couple gates, a chain and padlock and a couple .40 retention posts and be done with it. Pre made gates always come with the hinge points included as well. Have other things to do that fabricate up gates, I have the steel on hand but prefer not to.
   / gate or mobile barrier to block access to private road agricultural land #6
I live about 30 minutes from Priefert. They make the gates for the rodeos and a good gate for property entrances, too.
   / gate or mobile barrier to block access to private road agricultural land #7
I believe that is where my hay customer buys his rodeo gates and chutes at.
   / gate or mobile barrier to block access to private road agricultural land #8
They have an outlet sales location across the road from the plant. Locals can get good deals.
I just put in farm gates/drop gates, except for the driveway entrance. Cheaper than steel and more effective at discouraging strays.
   / gate or mobile barrier to block access to private road agricultural land #9
He's had them for a while now. Has a complete set of chutes and gates as he puts on sanctioned Rodeo's at all the county fairs around here and we get free admission as a perk. My wife likes Rodeo's. Me, not so much. I go to leer at all the 'cow girls' in the stands...lol He's been buying all the round bales I can make for years now. Never whines about the price either and always drops off a drop deck trailer in the field for me to load. I double stack them, he straps them down and off they go and he always settles up with me just before the end of the year, just like clockwork. In fact, last year I forgot about invoicing him and he reminded me that I didn't. Told him I'd just roll last years hay bales into this year. No big deal for me, especially dealing with a straight shoooter like him. Not like I'd go bankrupt without getting timely payment.
We get all our freezer beef from him as well. He raises his own bucking bulls as well as slaughter cattle and they all get fed from my round bales and I get to hunt on his ranch property every fall as well. Taken some huge whitetail does on his ground in the past.
I really 'lucked into it purely by accident. He is a farrier by trade and trimmed my wife's Percheron nags when we had horses and one day he asked me about the hay (I was doing idiot cubes at the time). Told me he only wanted rounds so I bought a NH round bailer and progressively switched over to rounds. The NH 4 series round bailer was a PITA, never netted properly or consistenty so I traded it on a new Kubota BV sileage special round bailer and never looked back I sold the square bailer on Tractor House, don't miss that either. I really disliked dealing with idiot cubes and all the grief that 'horsey people' like to do.
Got top buck for the NH 575 high capacity idiot cube bailer. I kept it like all my equipment, in tip top condition. Sold it for my asking price in 3 days to a fellow from out your way. He came up with a tractor trailer and we loaded the bailer up and off it went.
Now I have the ideal hay customer and the entire operation is 100% plug and play and like I said, wife likes rodeo's and I like leering at the cow girls.
He's a but miffed I turned back all my off farm hay ground and now just run the adjacent to the farm hay ground but at 76, it was past time to downsize anyway. The leasor that took over my leased ground, I believe he chiseled under the forage and is row cropping it but I could be wrong as I havem't looked at it since I cancelled the lease. The landholder had no issue with it either as him and his wife have been good friends with us for decades and he knows about my health issues (cancer) and he was expecting me to do it anyway. Just went to dinner with them last week. He's a retired Vet and sold his practice. he always took care of my wife's nags as well as our furry house pets and still does (furry house pets). Makes house calls always. Nice to be friends with a vet anyway. He always gets the prescription Heart Guard for the pups and flea stuff for the cats my wife adores and I don't.
Much easier on me to just run the farm ground, less fuel, less roading, less everything actually and I can stay on top of the herbicides and fertilizer easier. He wants almost pure alfalfa (vernal), which is what I grow. Considered Roundup Ready alfalfa but never followed through with that. Vernal is expensive enough as it is and my herbicide / pesticide regimen is 24D-B only plus liquid urea fertilizer I spay on between cuts.
The less grief I have the happier I am.
I'm not John Wayne
images
2014 HYUNDAI Veloster (A56859)
2014 HYUNDAI...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A55973)
2012 Peterbilt 386...
KODIAK 6' ROTARY MOWER (A52708)
KODIAK 6' ROTARY...
VINTAGE JOHNSON MOTOR (A58374)
VINTAGE JOHNSON...
2025 GPS 11.5ft Utility Trailer (A56859)
2025 GPS 11.5ft...
2000 JLG 800A TELESCOPIC/SCISSOR BOOM LIFT (A52709)
2000 JLG 800A...
